Question about Numark PT01 Turntable
Hi, I have a Numark PT-01 USB turntable that has a wobbling platter (where the record spins). It's not incredibly uneven, but it does wobble, and it affects the sound. How can I fix this?
djproaudio
  • 515 Answers
SOURCE: Loose / wobbly platter?
This is a common problem. If you have another 1200 turntable, switch out the platters and see if that fixes the problem. Usually, the problem does not carry over.
There is nothing to screw or tighten. You can install a new SPINDLE - and it should fix it. But might not be necessary if you just swap your platters out.
- OPTiC
DJ PRO LAB
Posted on Apr 21, 2008
djproaudio
  • 515 Answers
SOURCE: Numark TTX1 Turntable Problem-Platter stops
This is a drive issue. Unfortunately the TTX direct drive system isn't the greatest. It's good, but it's no Technics 1200. The only way to 'fix' this issue is to have a professional look at main circuit board to see if there are any components which are burned, or damaged in any way.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Posted on Nov 04, 2008
djproaudio
  • 515 Answers
SOURCE: cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Posted on Jan 11, 2009
djproaudio
  • 515 Answers
SOURCE: numark ttx with variable torque, platter turns slowly, weak torqu
More than likely one of the Drive IC's has failed, and needs to be replaced.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
  • 104 Answers
SOURCE: Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Posted on Feb 11, 2009
The plate on my numark tt USB is wobbiling
I find it hard to believe some of these answers. If the platter is wobbling, if you remove the platter, you'll find the spindle the platter rotates on. That will probably be loose. At the bottom of the spindle bearing, you will find a nut. Tighten that, and you should be in business. If you have further questions please visit my website at audioserviceclinic.com. You may contact me there.
Apr 26, 2015 | Numark ttUSB Turntable
How to fix a wobbly turntable stanton T.50
Check if the platter is oke and aint stock, and otherwise is you spindle bearing defect.... A platter ain't goes from flat to wobble all of a sudden. And try to get the stuf second hand, or better, buy a better unit, not from stanton, but a refurbished 1200mk from technics is ok, if you sprin records. If you only listen, take a loke at the rega and pro-ject sites.....
Jan 01, 2014 | Stanton T.50 Turntable
The platter wobbles
Why are there only 1 a 2 years questions left.... goodbye i leave this channel
Mar 22, 2013 | Numark TTX Turntable
Hi,my vestax 2300 platter has a slight wobble.i removed the platter and it seems 2 b the motor,can u help?
sliight wobble is normal but if its something you notice i suggest sending it to them to fix it
Apr 28, 2011 | Vestax PDX-2300 Turntable
The platter on my CDX is a bit lifted and wobbly. How can i fix that?
That is normal vinyl itself was never really straight and as for the platter it should have some give to it now if it looks like a bent rim on a bike then i would send it back but a little play is fine.
Apr 19, 2011 | Numark CDX Turntable
I have a brand-new ITUIT-201 USB turntable with a wobbly platter (slight wobble at lower speeds, and very noticable at higher speeds). This causes the record to spin unevenly, and the needle slides...
Sometimes you can push down on the platter high side to bend it gently to get it to turn level. Being brand new, you can also return the unit for repair or replacement at no cost. The cost of these things does not justify putting up with defects like this. Good luck!
Dec 30, 2010 | Garden
On my record player, the platter is wobbling as it spins and is off balance. what can be done to fix this
Remove the felt on the platter and lift the turning platter of the centre guide pin. Please note where the belt is running, because you will have to place that into the same possition as before. Check for any dirt or debries. Clean out and replace table and belt. Hope this helps
Aug 17, 2010 | ION Audio TTUSB10 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
My very old NAD 5025 got a hum noise problem
Check the motor shaft. It could be bent making the pully wobble which makes the whole turntable vibrate which gets passed through the needle. I just found this out on mine. Easy way to test is to hold the platter while the needle is resting on the record. The speakers will hum/wobble at a low frequency. Lift the needle off the record and the sound stops? It's the motor...
Jan 23, 2009 | NAD 533 Turntable
Platter or motor or what?
Been seeing a lot of problems like this on the newer decks. if the lights instead of moving smoothly are moving a bit, then stopping a little, then moving a bit more. or just wobbling a little bit usually has something to do with the motors... I have also just had to have mine replaced to was having the same problem.... expensive
Feb 16, 2008 | Technics SL-1210 Turntable
Numark PT01 Turntable Logo
288 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
