Question about RCA F27664 27" TV
I have audio and the set displays the channel number/ sound and menus. However it will not show the image that is playing on the tv
    Top Expert:
  • RCA Master
  • 75,311 Answers
Your TV has video problems. Input any video signal, from dish or from DVD player or any other source, after setting the TV to video mode. If there is video, fault may be in the RF video output section, which could be detected through through checking. If DVD video also in not there, the problem is of video swiching [usually electronic changeover inside the TV]. Which can be rectified through a technician.
Posted on Oct 14, 2010
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
Can't get sound on one channel
If it is an analogue channel then try fine tuning or manual tuning that channel.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 28, 2011 | GPX Televison & Video
My sony cyber shot DSC F717 digital camera has a problem. when turned on, no images on the screen. as well in the view finder.
This problem could be a number of things.
Does it allow you to have any access to the menus? If you can get to the menus, try setting the menus to default settings. Test the camera after setting the menus to default.
Can the camera play back images or videos and show on the screen? If they can be seen, then possible some setting is not right.
If you cannot see images when in recording mode try the play back mode and see if you can see any images in the lcd.
If you cannot see any images in either play back or record mode, and no menus, then the camera needs to be repaired.
If you can see images when you play back, and none when in record mode, then the ccd is suspected to be defective. If that is so, call Sony, give them your camera model and serial to see if they can repair the camera. The status will have to be determined by Sony repair.
Oct 20, 2009 | Sony Cybershot DSC-T200 Digital Camera
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
SAP
Hi Suezie,
The problem is most likely your SAP being turned On.
SAP was created for audio programing including translations into a 2nd language. On nearly all sets, the SAP being ON will essentially select an alternate audio stream and will de-select or mute the main audio from the channel your are viewing. However not all TV stations have SAP enabled.
I am the Chief Engineer of a TV station in Denver, CO. We are not using SAP so if you selected SAP while watching my station you would get noise or static. There would not be any audio there.
Go to the front panel of your TV and select the "MENU" function. Step through the menus to Audio features and De-select SAP or Enable your main audio and this should take care of the problem. Alternatively you might be able to unplug your set for a period of time and it would reset itself. I used to get calls from elderly viewers when the set wouldn't pick up the UHF TV stations anymore. These were always after a power failure and the set had defualted to factory settings,
Different set manufacturers use different menu schemes and withou a password feature, these menus are so simple a small child playing with those fascinating buttons can change them for you to something you really don't want.
Good luck and write back if you can't find it. The set manufacturer and model number would help me look up a menu tree for your TV set.
Thak you,
Bernarr Howell
Feb 03, 2008 | Televison & Video
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Cluster of stuck pixels
sounds like its stuck in another mode. Do you have the original remote to sdee if you can switch off the display section or the closed caption?? good Luck
Jul 28, 2006 | Toshiba 20AF43 20" TV
RCA F27664 27" TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
