Question about Galaxy Radios DX-949 40-Channels Base CB Radio
My galaxy 949 is not reciving or transmitting sometimes when i hit a bump it will start working but then hit another it goes back out i have checked the screws on the board they were loose but it did not help
    Guru:
  • 773 Answers
Lets hope its a loose or disconnected wire. If it's not it is possible you have a hair line crack in the board, which is a pain to fix.
Check all the wires going to the front panel of the radio. Pay close attention to the wires that go to the switch for CB/PA mode. If one of the wires comes disconnected, then it may be stuck in limbo between PA mode and CB mode.
If there are no loose wires, and there is a break in the board, then the only way to fix it is to find what traces are broke and solder jumpers past the breaks. It's a bit of work to find all the problem points.
Also, Inspect all the solder joints on the trace side of the board for cold solder joints. I would go over them and make sure all of the solder points are fully soldered.
Posted on Oct 14, 2010
My galaxy saturn recives but will not transmit. how do i fix this
you can take it to a tech and let him restore it because you don't possess the knowledge to repair it yourself.
Feb 14, 2015 | Radio Communications
My galaxy 949 will not transmit on sidebandwhy is that
There are too many possibilities as to what the fix is for your radio. You need to take your radio into a radio shop that services CB radios.
Oct 19, 2014 | Galaxy Radios DX-949 40-Channels Base CB...
Got a galaxy dx 949 mobile trying to wire a older d-104 to it and it dosent sound right its not got the mod it needs. thanks
Hello twelch,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
If it is the old four(4) wire mic, the wiring will be as follows:
Pin #1. Shield (Ground)
Pin #2. White (Audio)
Pin #3. Red (Transmit)
Pin #4. Black (Recieve)
If it is a SIX (6) wire! The Blue would go to Pin #1. with the Shield, and the Yellow
has no connection. I hope this was helpful to you. Your Comments and Testimony's are
always welcome here at FixYa. Thanks for choosing FixYa today and in the future.
John
Feb 27, 2011 | Galaxy Radios DX-949 40-Channels Base CB...
Finals shot? picked up a galaxy 949 and it does not transmit, if i replace the two finals or transistors what elnse needs to be done?
just follow service manual make sure its aligned properly .. some of those radios have pll problems too causing them not to TX...
Feb 07, 2011 | Galaxy Radios DX-949 40-Channels Base CB...
Powers up, recieves fine, breaksup on transmit Galaxy 949
Check the wiring on the mic plug sounds like you have a loose wire or one thats about to break off.Good luck.....Dan
Apr 01, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Blower fan goes off with hitting a bump
Check to see if any of the wire connections are loose.
Neil
Mar 14, 2009 | 2004 Pontiac Grand Prix
Galaxy 949 mobile CB is off frequency when
a friend of mine just told me he used the galaxy 2517 adjustment procedures. I hope this may help you. Buckeye back quiet.
Mar 03, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Speedometer work work sometimes. Hit a bump goes to zero.
suspect wiring fault ,remove battery and tray trace wiring from gearbox sender just behind mounting to were it goes into main wiring harness strip back tape usually 1/2 wires will have broken.this depends on which model of vw you have. vwsparky.
Jan 26, 2009 | 1997 Volkswagen Golf
Galaxy Radios DX-949 40-Channels Base CB Radio Logo
69 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
