Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi gas trimmer
We need to know the gas to oil ratio for our gas trimmer
LargoMO is correct. You may want to use the small (appox 2.6 oz.) plastic bottles of 2-cycle oil available at Lowes, Home Depot etc.. It is specially made for 2-stroke engines and emits less smoke etc. If you use the small bottles, you just put the oil in & then fill a one gal fuel can with gasoline and you are done. These engines use so little fuel that it may get old (that's not good) before a "typical" homeowner uses all of it ....in the event you mix more then one gallon at a time. The small oil bottles and a one gallon can are "just the ticket" for most of us. I have been using this mix in my Ryobi for 2+ years now with no spark plug changes or anything else...... and I string-trim a fenced 1-1/2 acre lot. The brand of oil is not all that important......just so it is for 2-cycle engines.
Posted on Aug 17, 2008
Just place a can of 2 cycle oil in a gallon of gasoline.  It will tell you on the can how many ounces to a gallon to use.
Posted on Jun 06, 2008
What is oil to gas ratio for a Ryobi TP30 pull start trimmer?
The Ryobi TP30 also has the model number RY52014. This 2-cycle engine uses a 50:1 gas to oil ratio. That means that for every gallon of gasoline, you need 2.6 oz. of 2-cycle engine oil. This information is available on page 9 of the manual. Manuals Lib has the manual for the TP30 trimmer here: https://www.manualslib.com/manual/143217/Ryobi-Ry52014.html .
I hope this helps.
Jan 29, 2017 | Ryobi Garden
I have a Ryobi Ry30522 weed whacker that i need to mix gas/oil for and I don't know the correct gas to oil ratio. The two cycle oil container has lots of different ratios ranging from 16:1 up to 100:1 and...
some of these machines are 40:1 and some are 50:1 please check your owners manual,or ask the shop where you bought it,be very careful as the incorrect mixture can damage the machine,rgds
Sep 25, 2010 | Ryobi Garden
Ratio for oil and gas on a ryobio weedeater
if you are using stihl oil the ratio is 50:1
Jul 03, 2010 | Ryobi Three Trimmer Combo
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
What is the correct fuel mix for the ryobi 790R trimmer?
The window ratio should be fine between 40/1 to 50/1.
Reduce oil ratio by increase gas part if some unburned oil can visible from the exhaust.
Someone else could have a better voice on this matter..
Jun 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas oil mixture
Hello slabieniec:
The Newer 2 Cycle Trimmers use a 50:1 Ratio (OEM Suggested Ratio). I Use a 40:1 Ratio in Most of my Equipment, Except for Chainsaws and Hole Drillers/Augers. For the Chainsaws I Use a 32:1 Ratio and the Hole Digger/Auger Uses a 25:1 Ratio.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Ryobi Garden
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Dec 10, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
May 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
293 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
