Question about Sony Reader Pocket PRS-300
My sony reader 300 wont turn on or off. it is stuck on the home page.I have tried reset button. when I plug it in the yellow light comes on and the screen says loading.when its finshed it still stuck on home page and won't turn on or off.Also the reader won't down load.and doesn,t seen to take a charge. It does appear to be fully chargeds Pls. help. thanks
ThaMp3Doctor
  • 8596 Answers
SOURCE: it wont charge
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Posted on Sep 14, 2008
SOURCE: My fully charge sony media player NWZ-E435F will not turn on
Hey...Just remove the Battery for 2mins, reload and Power ON again...It may work
-sai
Posted on May 21, 2009
SOURCE: my ps3 shows nothing but background waves, wont load main page
unplug PS3. Wait 10 minutes and turn on.
do the same with the power supply.
Posted on Aug 31, 2009
SOURCE: my sony walkman, model NWZ-S615F, is stuck on the
try holding all buttons and pressing reset several times,it worked for me,hope it works for you.
Posted on Oct 16, 2009
ani24das
  • 89 Answers
SOURCE: My Sony PRS600 does not fully charge. I had it
First, confirm whether you're using the AC-S5220EAC Adaptor to charge the Reader, as it's always recommended to use that one with the Sony Reader. However, you may also keep connected the Reader to the Computer for at least 4 hours to get it fully charged. If the issue still persist, perform a soft reset. To soft reset, please press the RESET button using a sharp-pointed object. Then, try charging it. That should resolve the issue.
Posted on Jan 26, 2010
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
Reader stuck on one page, no screen response to anything, soft reset no response, usb cable no response, power button no response.
Hi!
1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
2. Hit the reset button for 3 seconds at the bottom
3. The red steady light should come on, if not, try the reset again while the unit is connected
4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
5. Disconnect the reader and see if operational.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 31, 2011 | Sony PRS350
When i turn on my prs 300, the screen flickers and the light on top is yellow. when its done trying to turn on the light flashes a few times and thats it.. i've tryed several computers and they cant...
Hi jmjohnson198!
2. Hit the reset button for 3 seconds.
GoodLuck!
eBookBoy
Jul 16, 2011 | Sony Reader Pocket PRS-300
Just downloaded new books. Was reading one that night. Turned it off and went to bed. The next morning, I tried to turn it on to read more and it wouldn't come on. It was charged - not the problem. ...
Probably the its a frozen reader issue, try these steps:
1. Connect the reader to the computer
2. While the reader is connected hit the reset button for 3 seconds, and make sure the redlight comes on.
3. Leave the reader connected for 15 minutes, then disconnect it and see if operational now
4. If the reader still not turning on, try the reset and slide the power switch.
GoodLuck!
eBookBoy
Jun 23, 2011 | Sony Reader Pocket PRS-300
My sony ereader prs-650 is stuck on sleep mode and it wont do anything ,, it wont charge when connected to the computer
Each step in my solution is a possible resolution. Hence I suggest that you perform each step and check the operation.
Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to display the charging symbol if the Reader is fully drained in its last use.
Perform a soft reset. We can perform a soft reset by pressing the reset button on the Reader.
After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light next to the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptor and then press the reset button.
Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Reader device. Check if the Indicator light next to the power switch on the Reader device is yellow (indicating it is turning on) and if the unit is responding
If the unit is still frozen, connect it again to the computer or AC adapter and while connected, check if the Indicator light next to the power switch on the Reader device is red . If this light is red , allow the Reader device to charge for one hour so there is sufficient charge for troubleshooting.
Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader device between temperature extremes or if the Reader device has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader device to sit for a few hours before attempting to turn it back on
Jan 12, 2011 | Sony Reader Touch PRS-600
I plug it in to charge and the red light at the top comes on but the reader wont turn on. ive tried plugging it in to the computer as well as a wall outlet but same happened for both
as long as you have the reader plugged in, it will not work. Allow it to charge fully, then unplug it and turn it on. It is designed not to work while connected to a charger or computer.
Jan 09, 2011 | Sony Reader Pocket PRS-300
MY SONY POCKET IS FROZEN ON CAN NOT TURN OFF NONE OF THE FUNCTIONS WORK FROZEN ON HOME PAGE SOFT RESET DOES NOT DO ANYTHING?
Go to this link on from Sony e-support
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C1008849&fes=true&mdl=PRS300
mine was frozen and I could not turn it off - so I did a SOFT reset (just pressed the reset button with the end of a paperclip) with the reader ON (even though instructions say to turn off I didn't cause this was impossible to do), then slid the power button to reactivate - the yellow light came on, waited a few minutes -and it said opening book - and now all is fine
good luck, hope it works for you!!
May 06, 2010 | Sony Reader Pocket PRS-300
I bought the sony reader prs-300 for my girl on christmas 09
1. Connect the Reader to a different USB port of the Computer.
2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp.
3. Disconnect the Reader and then press the RESET button.
4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly.
5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
Feb 07, 2010 | Sony Reader Pocket PRS-300
Sony PSR 300 e-reader frozen screen
since you've tried charging the reader using a non-compatible charger, there might be some internal malfunction occurred in the reader. however, i suggest that you try charging it by connecting it toi the computer. as the yellow ligjht is is blinking, it seems that there is no chrage in the reader. so try charging it by connecting it toi the computer.keep it connected for at least 4 hours. it should resolve the issue.
Jan 28, 2010 | Sony E-reader Portable E-book MP3 Player
Sony Reader Pocket PRS-300 Logo
333 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
