Question about KitchenAid KHWS01PMT Front Load Washer
Leaking around the bottom of the front door - KitchenAid KHWS01PMT Front Load Washer
  • 254 Answers
Check your main door gasket/boot for tears that is the most common issue for leaks out the front door.
Posted on Oct 13, 2010
  • kbwoodard Oct 13, 2010
    This may be so. The other cause, that I found and fixed, is to remove the bottom panel from the front (three screws) and find the collection junction that is inline with the pump. It is usually white and has a straight piece on the front. Unscrew this (counterclockwise) and check inside...GOLDMINE. These are the pieces that are preventing the water from exiting in a timely manner and they make the water back up through the system.
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Mar 16, 2009 | LG WM2688H Front Load Washer
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Jul 25, 2008 | LG WM-2277HW Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
KitchenAid KHWS01PMT Front Load Washer Logo
57 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
