Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My cabrio top loader is very loud in the spin cycle .With or withot a load.machine is balanced properly
  • vclarke10821 Oct 13, 2010
    I will try this solution is it hard to change bearings & water seal
  • 2,382 Answers
Hi, it means that the inner bearing is be faulty, kindly replace the inner bearings as well as water seal. Before that kindly check whether the drum is freely moving without any shaking. If you find any shaking, it means you are suppose to change the drum only......
Posted on Oct 13, 2010
  • Tunde Autos
    Tunde Autos Oct 13, 2010
    Hi, if you are not technically inclined with washing machine, just call in a tech to fix it up. It is not something anybody can do especially the bearing and drum......
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer making a loud noise on spin cycle..cabrio model top loader..
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
Sep 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My kenmore elite top loader has a loud banging noise when spinning
Disconnect power to the washer then tape the lid closed. Lay the washer carefully on its front panel on a padded surface then check the four suspension spring/rod assembly. Make sure the suspension doors are properly attached to the outer tub to prevent an off balance situation that may lead to the banging of the basket to the outer tub during the spin cycle. Also ensure the machine is balanced and properly or evenly seated on the floor.
May 07, 2010 | Washing Machines
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
252 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
