Question about Presto 02621 Juicer
Presto homeade I lost the top part that squeezes the lemons, where can I get a new part.
Www.gopresto.com enter stock # 02621 and you will see replacement parts listed. The piece you are looking for is $4.00
Posted on Aug 16, 2008
BADLY SQUEEZES OUT VEGETABLES
Search Results
    45 Uses For Lemons That Will Blow Your Socks Off
    preventdisease.com/.../052713_45-Uses-For-Lemons-That-Will-Blow-Y...
    May 27, 2013 - You can make sure the white vegetables stay white by squeezing a teaspoon ... Slice your lemon and squeeze out one tablespoon of lemon juice into ... alters the pH level in your mouth, killing bacteria that causes bad breath.
    Bad news for vegetarians! Plants can 'hear ... - Daily Mail
    www.dailymail.co.uk/.../Bad-news-vegetarians-Plants-hear-eat...
    Daily MailJul 2, 2014 - Researchers in Bonn, Germany, found plants give off a gas when under 'attack'. ... The research could help to work out which pieces of fruit and vegetables ..... creates YouTube channel dedicated to spot squeezing - and her.
    The GP who gave up fruit and veg to cure her aches and ...
    www.dailymail.co.uk/.../The-GP-gave-fruit-veg-cure-aches-pa...
    Daily MailJul 16, 2012 - I slept badly - I suffered from restless legs and my muscles kept ... cutting out virtually all 'healthy' food - I avoided most fruits and vegetables, salads, ..... in a series of sold-out seasonal shows; Casey Batchelor squeezes her ...
    Market Dis. of Fruits and Vegetables: Citrus and Other
Dec 16, 2015 | Juicers
The wire basket of my Breville Juicer is rusted. is there a safe way to remove the rust or am I going to have to buy a new part? if it the the former, what should I use? if it is the latter, where can
I am not sure how rusted it is, but it should be fairly easy to clean.
I would start with either distilled white vinegar or fresh lemon juice. You should have good results with either.
Otherwise Breville does have an 800 number or just google the model number and part name, the part should be available.
Feb 13, 2015 | Breville Juicers
Freeze sliced apples
A little lemon juice will keep them from turning brown. If you don't care about brown, don't bother.
Sep 11, 2014 | Juicers
Why is the pulp warm/hot? the screen is clean...
It is caused by friction as the cutter assembly squeezes the pulp out. The tighter the squeeze the more juice that is extracted. Be sure to oil the shaft with only olive or coconut oil as these oils will withstand the high temperature without getting gummy and making the cutter stick to the shaft..
Sep 04, 2014 | Champion Juicers
Moulinex masterchef 470
customer care department:
English
Monday - Friday at 9:00 am till 8:00 pm EST
Saturday and Sunday at 9:00 am till 5:00 pm EST
Espa?ol
Monday - Friday at 9:00 am till 6:00 pm EST
Saturday and Sunday CLOSED
Phone: 1 (973) 287-5150
Jack LaLanne Power Juicer Official Website Exclusive Offer Buy 1 Get 1...
Aug 21, 2014 | Jack Lalanne Juicers
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
Could you please tell me if i have to remove the peel before using the juicer
What does the manual say? Depending on the item your putting in is whether or not you have to peel it or not. Typically no, you don't peel the fruit before using a hand juicer, but it it's a matter of taste.
I don't peel mine.. I aim to get all the vitamins and minerals that i can obtain from fresh fruits and veggies.
Some oils in the peel are making the juice bitter though, you have to do a trial and error on that. On Lemons because the white pith on the lemon (just under the yellow bit) can be quite bitter, and it will inadvertantly end up in your drink.
It will not cause you any problems if you do not peel the lemon. It's just a matter of taste. I just looked through all my juicer manuals and "Juiceman" says to leave them all on except for oranges and grapefruit due to their "extreme bitterness". My Waring manual (the one I use now) says you can do it either way but recommends you buy their citrus reamer. The other manuals say to peel them.
If this advice was helpful a vote for the thumbs up would be greatly appreciated
Mar 24, 2011 | Juicers
How to clean a juiceman junior
easiest way and tricky. Juice a couple of lemons or limes then or with alot of water. The acid in the lemon will kill any bacteria the water will rince it out.
Jan 16, 2010 | Juicers
Cleaning a Mesh Filter on my Juicer
The stiff brush that came with mine has worked well for me. Have you tried a fingernail brush or maybe some canned air?
Nov 19, 2007 | Juicers
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Presto 02621 Juicer Logo
80 people viewed this question
Top Presto Juicers Experts
eyecam
David Payne
David Payne
Are you a Presto Juicer Expert? Answer questions, earn points and help others
