Question about Solar Security Or Vacation Mechanical Onoff Timer Lights Tv
How to set a peg security light timer has little peg that yu set to different times and turn but I do not understand where to put the pegs
  • Anonymous Oct 14, 2010
    Can you give a model number and more information about the peg so I can look up the manual?
The rock tumbler will not turn on, the light on the day settings just blinks off and on.
the clear cover on top has a clasp at the BACK and a clasp with two clear pegs on either side of the clasp on the FRONT.. more than likely your two clear pegs are not closing the safety interlock, make sure you have the lid with pegs to the front and hold down while pushing the on button .. the lights blink to tell you the lid safety interlock is not secured.
Dec 28, 2011 | California Creations Dp Rock Tumbler
Need to set the timer properly. No instructions to follow. Want lights to come on at 6PM and off at 6AM. the timer has red and black pegs on the timer, HEL:P
Experiment with the timer.
Hook up the lights and timer. And read resource link below.
Put the trippers on the dial. Put red at 6pm and black at 6am.
Then manually rotate the dial two revolutions.
Turn the override knob to different setting, and then manually rotate the dial two revolutions.
Watch what the lights do as you rotate timer dial.
Then rotate dial two revolutions until current time lines up with stationary arrowhead located on inner dial.
The clock motor located inside timer rotates the dial, and trippers move small switch that turns lights on-and-off.
More resources with important tips for power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/How-to-set-timers.html
Sep 27, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
Noma indoor mechanical timer. Cannot figure it out, not enough instructions. Set it to come on at 6pm and go off at 10pm, set current time at 2pm. plugged in light and it came on now shouldn't it have...
Insert the OFF peg, to the time you want the light to turn off. Set the clock to around 1 hour before the actual time of day and put the ON peg in at around 1:15, but NOT all the way in, just far enough in so you can see it will engage the post pin under the "T". Now plug it in, and adjust you time to 2:00 or whatever time it is. Just make sure you preset the 24 hour clock to around 1 hour before the actual time of day and put the ON post in near the "T", so when you do adjust the clock it will engage and turn the light off. Then depress the middle button, pull the ON post out and place it at the time of day you want the light or appliance to turn on. Push the ON post all the way in.
This was the easiest way I found to do it, on the NOMA mechanical timer.
Nov 27, 2010 | Kitchen Appliances - Others
Have a new woods tn300 light timer. if lift the
Anywhere that pegs are pulled up is where the outlet is off if the pegs are down then the outlet is on. Hope that helps!
Jan 09, 2010 | Kitchen Appliances - Others
Woods Model 59200V Indoor Mechanical Timer. Not working
book says peg should be down for on and peg should be up for stop. How the hell does one pull the peg up...it is blocked and can only be pushed down...now what I am missing?
Dec 18, 2009 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Just as someone else wrote, I too have the Malibu light timer and have the blue & red pegs set to turn on (red peg) at 7pm and off (black peg) at 11pm. The lights will not automatically turn on...I...
The clock motor has gotten weak and is now overheating, and will soon stop turning. There are no replacement clock motors for ML series power packs.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Nov 09, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu landscape transformer
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Apr 14, 2009 | Intermatic Malibu 300W Power Pack...
Solar Security Or Vacation Mechanical Onoff Timer Lights Tv Logo
180 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
