Question about Nintendo Wii Console
Will not power up pretty sure power cable is ok
    Problem Solver:
  • 35 Answers
Buy another cable
Posted on Oct 14, 2010
What's wrong? My Lowrance Mark 5x dsi depth finder flashes or pulsates a depth of 60 ft. All the time.
Since the unit powers up, we can pretty much eliminate a power supply problem.
I would start by carefully inspecting your transducer lead for kinks, crushing etc. Assuming the cable is OK, clean and lubricate (silicone spray, safe for plastics) the cable end and where the cable connects to the unit.
Hope this is helpful to you.
-Steve
May 04, 2015 | Lowrance Boating
Wire schematic
The LCD cable is a ribbon cable - a collection of wires all banded together in a flat-moulded lead. This connects to the rear of the LCD panel and then to the motherboard of the laptop
Aug 04, 2014 | HP 17.3" Pavilion G7 Notebook Computer -...
Replace power supply motherboard
Replacing power supply mother board risks fire and shock. For the cost of a new supply, It is far better to replace it. I believe that is a standard power supply. You can buy them from Staples or Best Buy for cheap.. If you're not sure of the correct part, remove the old one (only 4 screws and a few cables) Make note of cable connection locations.. but really, it is pretty hard to put a plug into the wrong socket. Bring the old supply to your supplier of choice and match it with a new one.. Higher wattage is OK, lower is not
Good luck
Jan 15, 2014 | HEWLETT-PACKARD Hewlett Packard Pavilion...
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 09, 2010 | Sony VAIO VGN-FW140E/W Laptop
Emerson Model EDW 2203 DVD/VCR Player
Mar 02, 2010 | Emerson EWD2203 DVD Player/VCR
I have a burned out Bestec ATX-250-12z power supply for a hp pavilion a320n. I need to know if a Dynex® - 400-Watt ATX CPU Power Supply, will work in its place.
yes it should do provided your current psu is not a small mATX one. ATX power supplies are pretty generic. Make sure you get one that has enough connectors to suit your system, having said that, Considering it's an off the shelf PC I would guess most PSU's would have the right number and type of connections.
Jan 10, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Washburn amp no power
Hiya, check the obvious first, fuse, power cable, power switch make sure they OK.
If problems not there, then is probably main board power supply/transformer but i'm sure you can find someone in the area with electronic experience (start with the transformer). Nice thing about old gear is that the electronics was always pretty much the same and simple.
Hope that helps
Jul 24, 2009 | Washburn Amplifiers: 25 WATT Guitar...
My car won't start even when the battery is fully charged. Every time I turn the key to start I hear a click.
make sure the battery cables are on tight it sounds to me like one of the cable maybe loose
Jan 17, 2009 | 2002 Pontiac Aztek
Hand brake cable
u should pull the brake strap in your car.pretty complicated to do it by your self.take it to the closer garage.its not expansive--it's something around 60-70 bucks.
May 28, 2008 | 2000 Ford Focus
Hooking up a console
well i would run it throw direct to tv ok then digital out from tv back down to this digital inn ok of samsung use hdmi to hd tv fro xbod 20 tims better looking
Dec 29, 2007 | Samsung HT-X50 System
Nintendo Wii Console Logo
75 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
