Question about Sony ICF-SW7600 AM/FM/SW Radio
Antenna has snapped off at screw - Sony ICF-SW7600 AM/FM/SW Radio
  • 64 Answers
Thats sad to hear. But its like getting a new one if you will purchase just the antenna from Sony SpareParts department.
Posted on Oct 14, 2010
How change front fender f150 2000
Fender -Front Removal
  1. Remove the radiator grille opening panel reinforcement (8A284).
  1. If equipped, remove the front wheel opening moulding.
    1. Remove the pin-type retainer.
    1. Remove the screws.
    1. Remove the wheel opening moulding.
  1. Remove the front fender splash shield (16103).
    1. Remove the pin-type retainers.
    1. Remove the front fender splash shield.
  1. Remove the cowl grille.
  1. On RH front fender, remove the antenna mast.
  1. On RH front fender, remove the antenna base.
    1. Remove the radio antenna base cap (18A927) by gently inserting a thin straight-edged screwdriver underneath the cap and carefully following inside the perimeter until both snaps are free.
    1. Lift the antenna base.
    1. Disconnect the radio antenna lead-in cable (18812) and remove the antenna base.
  1. Remove the fender stuffer.
  1. Remove the stone guard.
  1. Remove the front fender.
    • Remove the bolts.
Sep 17, 2014 | 2000 Ford F150 Flareside SuperCab
Antenna snapped off
Perhaps you can use a broken screw remover that you can purchase from you local hardware store.
Jan 12, 2014 | 2012 Honda CR-V
Antenna
rod screw type antenna you have to replace whole antenna.just screw out old antenna screw new antenna in place.
Jul 01, 2013 | GMC Cars & Trucks
How do you fix a snapped off antenna on a kia soul
@womonsoft7 I'm giddy with childish excitement because this actually worked for me "If you're lucky, you can sometimes just push a screwdriver against the edge of the screw and rotate the screw out that way". After reading this I thought it would be worth a try...It just happened to be loose enough for this to work. My Antenna was broken off by a low clearance garage door, actually thought I smashed in the roof, but it was just the antenna. Easiest fix imaginable.
Jan 07, 2012 | 2010 Kia Soul
I am trying to put an extended NNTN5539A antenna on my i355 phone, but I can't figure out how to remove the original antenna. I saw on one forum where someone said there was a tool to remove it, then I...
It's simple. In order to install the antenna, you must do the following:
Using a very small "star" type screwdriver, remove three screws from the base of the unit. Remove the base trim piece. The body of the phone is in two pieces (front and back). Use a knife to separate the pieces by first GENTLY lifting the locking tabs on the bottom of the unit so that they will easily unsnap by themselves, just lift them a little bit, not all the way. Insert the blade along the side of the seam and pry gently.
Slowly remove the back. There will be adhesive tape at the top piece, so work slowly. Notice the locking tabs on the sides, they will come apart by themselves, no need to worry about it.
After separating the halves, unscrew the top of the original antenna, screw the new antenna in place, slide the back atenna opening over the new antenna and snap into place, making certain that the side tabs insert properly. Just use your eyes and common sense. Do not force anything, but snapping the halves back together will require a firm force.
Replace the bottom trim piece and three screws, you're done!
Mar 11, 2011 | Cell Phones
The antenna was snapped off of my 2008 Honda CR-V, snapping the bolt that is used to screw the antenna to the base. How do you fix this?
If the remainder of the bolt protrudes above the surrounding metal(you'll need about 1mm), you can cut a groove with a hacksaw into the bolt and screw it out with a screwdriver. If this is not possible you can use an "Easy-out" and here is where you start purchasing items.
This entails drilling into the bolt shaft using a drill bit about half the diameter of the bolt shaft itself. The correct size "Easy-out" tool is then screwed into the newly made hole(it screws in counter clockwise) and as the tool grips the inside of the bolt shaft it will unscrew the bolt shaft.
A third alternative would be to drill out the bolt completely and use what is called a heli-coil to repair the hole. I doubt the last will be viable as there is not much metal to work with.
As a last resort you can purchase an aftermarket antenna and install it in a differant place on the car's bodywork.
Oct 04, 2010 | Honda CR-V Cars & Trucks
Need to remove fender trim to get to wheel well to expose power antenna can't remove outer fender trim ?
There are several screws inside the fender well that have to be removed and one in the pinch molding of the car that has to be removed the ones near the engine are snap in plugs and can be removed if you use a flat tip screw driver to remove the plastic push in locks. Remove them to get to the antenna.
Sep 05, 2009 | 1990 Toyota 4Runner
Is there an easy fix to screw in antenna snapped of in mount
You can drill out the snapped-off screw and re-tap the hole. Then just put in a new (and slightly larger) screw. You will probably need a larger screw if you drill it out past the existing threaded hole. If you're lucky, you can sometimes just push a screwdriver against the edge of the screw and rotate the screw out that way until you can grip it with pliers and unscrew it. Then just put in a new screw.
Feb 12, 2009 | 2007 Honda CR-V
Broken antenna
It is not Very Easy to get to But, You can access this through the Fender Holes under the Hood. Please Rate My Response! Thanks!
Feb 05, 2009 | 2002 GMC Yukon XL
How do you get the KX-TGA270S apart to replace the Antenna
Real easy... remove the battery and you'll see 2 screws. then start peeling the phone in half from where the screws were.. the phone may seem like its breaking but it does snap apart... then you will needs a soldering iron to replace the antenna..
Nov 13, 2007 | Panasonic KX TGA270S Cordless Expansion...
Sony ICF-SW7600 AM/FM/SW Radio Logo
73 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
