Question about Aquacal HEAT PUMP 120,000 BTU H135 -
HEAT PUMP SAYS WATER TEMP IS 99 DEGREES WHEN ITS 82 CAUSEING PUMP NOT TO TURN ON WHATS THE REMEDY NOT SURE ON BTUS MODEL NUMBER IS 120AHDEBNC AQUACAL kind of in a bind thanks
  • Anonymous Mar 31, 2014
    parts lists and exploded view of equipment
  • 990 Answers
This is a bad temp sensor or an open by-pass. You would have to go to your book to find these though. I'm not sure where you would find them.
Posted on Oct 13, 2010
Heater will not come on.
You need to put a volt meter on the wire that goes from the Aqualink to the heater and verify that it is telling the heater to turn on. Then we can determine if it an issue with the Aqualink or the heat pump. Make sure that the water temp sensor on the AL is reading actual temp. Sometimes they will read incorrectly and, for example, display that the water is 142 degrees. If the AL thinks the water is already at or above temperature it will not close the switch for the heater to start.
Mar 29, 2014 | Jandy AE3000T-R AE-Ti Heat Pump 137K BTU...
I have a westinghouse window unit and I think it has heat strips for the heat. How do I tell if it is a true heat pump or if it has heat strips and how do I get to the Heat strips in the unit to check.
If it is a heat pump, the compressor will be running both in cool mode and in normal heat mode.
Confirm the current indoor temperature. Turn the thermostat up one degree at a time until it comes on. This will typically be 1 to 4 degrees increase. As soon as it comes on stop increasing the temp.
If the compressor is running, it is a heat pump.
Check the temperature coming our of the vents at that time. You should have 30 to 60 degrees increase from the air temp going into the unit and the conditioned air temp coming out.
Then turn the T-stat up another 10 degrees. If the temp coming out of the vents increases by 20 degrees or more. the strips are on.
The strips operate in three situations.
1) the system is set to emergency heat
2) The heat pump cannot keep up with the demand for heat. (because its too cold outside, the desired temp setting is greater than 4 to 8 degrees above the room temp, or the HP is malfunctioning.)
3) The HP is in defrost mode
You could also take the panels off the unit and look for a reversing valve, but unless you know what you are looking for you will not recognise it.
Oct 12, 2009 | Heating & Cooling
Jandy Pool Heater model AT550 - what is error D4?
check safety circuit then ignitor then gas then temp sensor
Sep 06, 2009 | Jandy Air Energy Heat Pump - 100,000 Btus
Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
Sep 04, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
I would like to know the specifications of my Goodman model CPKE42-18 AC/Heat pump system. BTUs heating and cooling? Thank You,
Many HVAC people talk in tonnage. One ton is equal to 12,000 Btus. Therefore your model specifies your cooling tonnage at 3 and 1\2 tons. Your heating would be determined by how many if any supllimentary heat strips are added. If you live in Anahiem or Miami that's not really important. But if you live anywhere that gets down into the 40's at night you'll want strips. Cooling wise depending on where you live and what your insulation is like, I'd say your unit is good for 1100-1300 Sq feet of living space.
Jul 15, 2009 | Goodman Heating & Cooling
On Load the working temperature rises
at 100 degrees c the aux fan will come on. Make sure that fan is working properly and also that your fan clutch is working properly.If this is happening with the a/c on there is an updated temp switch for aux fan operation on the receiver drier. It should be red in color. The temp is going to rise under different loads but that is a bit extreme in my opinion. Make sure you have a 50 50 mix of water and coolant and that the rad. cap seal is o.k. assuming the rest of your cooling system is in proper working order.
May 30, 2009 | 1987 Mercedes-Benz 300-Class
No hot water
in and out hooked up right?
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Aquacal HEAT PUMP 120,000 BTU H135 - Logo
303 people viewed this question
Top Aquacal Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Aquacal Pool and Spa Expert? Answer questions, earn points and help others
