Question about Kenmore 64802 Top Freezer Refrigerator
I have water collecting at the bottom of the frig under the crisper drawers. It appears to be coming from the freezer. Do I need to defrost and if so how?
  • 254 Answers
It shouldnt need to be defrosted if it is a frost free refer. It sounds like your defrost drain line is clogged and backing up. Check the drain pan underneath refer.
Posted on Oct 13, 2010
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Posted on Mar 11, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Water collecting under crisper drawer at bottom of
There is a leak somewhere in your defrost drain. Most times this is caused by a blockage near the area of the leakage. Below is a link to a very informative way to help you resolve the problem. Thanks.
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on Jun 28, 2009
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Water collecting under bottom draws inside frig
That water is very likely dripping from the freezer because the drain for the defrost is blocked,so instead of the water draining its dripping through the vents down under the crispers. This tip i wrote will help ya to clear that drain to keep the water from dripping through the vents.
http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Magic Chef CTF1826AR Top Freezer...
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
Water has been collecting on the bottom tray of my frig (under the vegetable & fruit crispers). I have a top freezer Frigidaire. The back coils are clean and the door seals seem ok. What can I do?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 06, 2010 | Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
GE with top freezer has water accumulating in bottom of frig under the crisper drawers.
Remove the food from the freezer , then remove the icemaker , if it has one ( 2 screws ) . Remove the rear freezer panel . Useing a hair dryer , start in the middle of the drain trough , and defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water will go thru . Use a piece of tubing inserted into the hole , and blow thru , to remove any debris accumulated in drain line .Remove any excess ice from trough . Reassemble freezer .
Aug 27, 2009 | GE Refrigerators
Water collecting under crisper drawer at bottom of frig.
Jun 28, 2009 | Refrigerators
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Mar 11, 2009 | Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
129 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
