Question about Kodak EASYSHARE 5100 All-In-One Printer
I just replaced the ink cartridges in the 5100 printer-copier and the print still comes out faded-p-not as dark and clear as of a month ago. What do I do to get darker, clearer printing?
You will need to change the printing resolution to get a darker print. Open up the Kodak Easyshare 5100 software and go into the tools and set your resolution to the darkest setting. Another thing you can do is clean the print nozzles with rubbing alcohol
Click on the link below to download the KODAK 5100 All-in-One Printer Software:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9099&product=EKN033539
Click on the link below to learn how to clean the printers nozzles:
http://www.ehow.com/how_5022932_clean-print-cartridge-nozzles.html
Posted on Oct 13, 2010
New ink cartridges in 5100 printing almost as if running out of ink print is faded how to adjust for best results
Most likely you need a new printhead. Call Kodak. Our 5100 has had printheads replaced. They will ask you if you calibrate & clean printhead. Do those first before calling. It is in maintenance. To find maintenance, click on the ? mark.
Sep 03, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
The red colour is faded. i'm trying to print out a photo which is fire engine red and it is coming out peach. the ink isnt low. ive cleaned the printer heads, and nozzle checked it. no difference. the...
Did you clean the printer heads manually with alcohol and a Qtip?
Also pop out the red cartridge, cover the hole and give it a good shake, then try again.
Chances are the red ink simply wasn't as "fresh" as the others.
Oct 19, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
It prints improperly, dark on top then fades to nothing.
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
a.On your computer, open your Kodak AiO Home Center software.
b.Click on the Help (?) button.
c.Click on the Maintenance option.
d.Click on the Clean Printhead option.
3.Print Demo Page.
Press Scan and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer requires replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
MY PRINTER WILL PRINT IN FADED COLOR. I REPLACE BOTH COLOR AND BLACK INK CARTRIDGES. STILL NO PRINT. THE LAST TIME THIS HAPPENED WAS A FEW MONTHS AGO AND I WAS TOLD I NEEDED A NEW PRINT HEAD. THIS WILL BE...
If you are not using the printer that often, the ink may be drying out.. once the ink is dry on the printhead, it could very well be the cause of the problem.
Check out the link below:
http://www.kodak.com/go/itg
For image quality issues, this is the place to go for troubleshooting them and getting a replacement head if needed.
Jul 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Why wont the colors print out dark i even replaced the ink already. still nothing i have only owned it for like 6 months
Sounds to me like the printhead needs to be cleaned out, it has ink residue on it from the other cartridges you had in there. Page 47 in the manual for your printer explains how to remove the printhead from the printer. Here is the link to the manual for your printer: http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5100AiOPrinterUG_EN-US.pdf Inside of the printhead you'll see holes where the ink cartridges are normally above. Those holes need to be cleaned out. I suggest you soak the bottom of the printhead in some warm water overnight. This will enable for the ink residue to fade away and then you can take out the printhead from the warm water and dry it all off. Put it back into the printer with the cartridges installed and then print a few diagnostic pages to give the ink a chance for it to flow properly.
Jun 11, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can print paper but photos have green tint
If you refilled the ink cartridges, this can happen. Kodak uses pigment based inks, the others use dye based inks. Also, make sure your printer is set for normal photo printing, rather than special effects.
Jan 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer not printing black ink
Contact Kodak with your problem. The problem is in the print head. Kodak will send you a new print head free, then follow the instructions that are inclosed to change the print head. DO NOT TRY TO CHANGE IT WITHOUT READING THE INSTRUCTIONS. You may damage the new head and they will not replace it a second time for free.
Dec 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo.  The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded.  I have tried every troubleshooting tip in the book and still no luck.
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
63 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
