Question about Whirlpool Electric Dryer Heating Element 279838
No heat, blower runs, 110 volts to both sides of the element when dryer turned on......
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Dryer is spinning but not heating. we cleaned vents, unplugged dryer and replugged in. now it still won't heat and an hourglass symbol has appeared on control panel
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 11, 2015 | Samsung DV419AE Dryer
Beko drcs76b dryer not heating up, i have changed the heat element but still blowing cold air, any suggestions?
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Apr 03, 2015 | Dryers
When this unit runs it doesn't get very warm. I checked the elements they are good. I read 211 volts on each of the 6 elements, and 22 volts on the control side??
did u check the element for continuity?
ELECTRIC Dryer no heat or little heat:
Mar 30, 2015 | Dryers
I replaced the heating element and the high limit thermostat and thethermal fuse and the dryer still does not get hot
Mar 20, 2015 | Whirlpool Dryers
My kenmore dryer model#110.61202013 wont heat up
Feb 22, 2015 | Kenmore Dryers
Turned dryer on.dryer runs but timer won't advance and won't produce heat.
Jul 04, 2014 | GE Dryers
Kenmore gas dryer model 110 775 42600 won't heat what is wrong
Jul 04, 2014 | Kenmore 500 6952 Dryer
My gas kenmore 80 series is not heating?
May 20, 2014 | Kenmore 80 Series Heating Element -...
My dryer is running, but doesn't have heat.
All electric dryers use 220-240 volts of electricity to run. The elements that make the heat are what actually need the 220 volts, the motor that turns the drum only uses 110. If you have a fused service disconnect box, replace both fuses, as one side is gone. 220/240 is made up of two 110/120 lines coming in, if one fuse, one side, blows, then all that's left is the 110/120 needed to run the drum motor, but no 220/240 to run the heat element. If there is no service disconnect then check the breaker than runs the dryer, flip it off and then back on to see if that makes any difference. Sometimes it will. Then there's the possibility that the hi-limit thermostat on the heat chamber in the machine blew, letting the drum run, but not feeding the coils. If you're not real handy with tools you may want to call a repair tech for this one.
Apr 22, 2011 | GE Profile Harmony DPGT750EC Electric...
Whirlpool Electric Dryer Heating Element 279838 Logo
128 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
