Question about Maytag Neptune MAH5500B Front Load Washer
Neptune front load washer
We have moved to France with a Neptune washer and would like to change the power supply from USA electricity to France electric standards. From the manual and the back of the washer it appears that this is possible. How do I figure out exactly what I must change?
    Genius:
  • 1,028 Answers
If i remember correctly usa is 60 cycles and european is 50 ..might be wrong but don't think it's possible without a lot of changes ..best get an adaptor if available..this should plug into foreign outlet and then plug washer into it
Posted on Jun 02, 2008
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Need free service and repair manual for Maytag Neptune MAH8700AWW front load washer
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Oct 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
After a complete cycle the drum fills (slowly) with water leaving clothes soaked.maytag Neptune front loader
This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Take all power off the washer then turn one or the other off and see which one is causing the problem. Sorry but it needs replacing. If it only happens when there is power supplied to the washer, a service call is required to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
The machine was in use and we had a short power failure. Now it will not turn back on. Please help.
Check the supply socket if you have not already done so by plugging in a kettle for instance. If no power check all of your breakers/fuses (sorry I'm English!). Does your washer have a fuse in its plug? Check that. If all OK then I'm sorry but it looks like a service call is required ;-0)
John C
Jun 05, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Need a manual for washer model # mah8700aww
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 25, 2011 | Maytag MAH8700AWM Neptune Front Load...
Hi! I have a Maytag Neptune front loading washer machine. On a few occasions I have found a small amount of water in the drum before starting my weekly laundry. Today when I went to start my laundry...
This is symptomatic of a water control valve not closing completely- its no power/fail position is closed.
Whichever it is, hot or cold, needs replacing!
Service call ;-0(
Good luck,
John C
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
How can I have the manual of this washer, Neptune MAH 5500 B. Can I order to Internet ??? My e-mail is: muffin10_us@yahoo.com Thank you. Angelo I have no problem, I need the manual to know how to use.
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems ;-0)
Good luck,
John C
Feb 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
Mel dew on rubber around washer door
you would need to change the bellows gasket
Feb 24, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune front loader
I would say that you have damaged your door lock. Most appliances have a door lock or a mico switch. this is the first port of call for the power to supply the w/machine.Safety measures??? go back to basics,is the door locking, any power to the going to the electronics. a door. Change faulty components???
Aug 14, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
