Question about Mitsubishi WS-65511 65" Rear Projection Television
Ws-65511 error code 22 sd tech - Mitsubishi WS-65511 65" Rear Projection Television
    Genius:
  • 1,030 Answers
Error code 22 is an indication of a short in a low voltage power supplies
Posted on Oct 13, 2010
  • gahmsrefrig Oct 14, 2010
    thanks...i have done alot of research on this tv and found 2 obvious defects on this set.... and almost all failures ive read about are caused by these 2 problems ...the very common thermal paste drying out and causing the convergence ic failure that also blows fuses when it goes and i think several people mentioned resistors that fail on convergence ic failure....the other problem was 4 capacitors that fail on another board....i was trying to get a guy on here named sd tech to email me the circuit board pictures in which he has labeled the parts i need to replace on both repairs...i have static strap, solder removal tool, nice soldering gun, have replaced many components on obsolete hvac circuit boards so i guess i have enough experience to solder in a few parts...the only thing im missing is something that correctly identifies those components visually as i looked at the very complicated electrical system covering quite a few large circuit boards...i really wanted to be sure before i start as this tv cost over $3000 ...this site seemed to offer the best info on these repairs and im glad i found it...ive already given back by helping another with a hvac problem..thanks for your help
Mitsubishi WS-A55 with a 2-3 error code
SD Tech - I have the error code 22 on my WS-A55. Power light comes on and then quickly shuts off. Looked at circuit board - there was greenish "gunk" on two of the electronic parts on the board in the center (behind the speaker grill) in the area labelled R5A62. Would you be so kind as to post repair instructions and the name of parts seller you mentioned above? Thanks!!!
Mar 17, 2013 | Mitsubishi WS-48315 48" Rear Projection...
Tip
Mitsubishi WS-65511 Manual Download
Download Mitsubishi WS-65511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-65511 VChip Password
Bypass Mitsubishi WS-65511 Front Lock
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
Won't turn on
If power light comes on for a few seconds and goes off: on front of set press and hold both the Menu and input buttons for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Please let me know what error code you find and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65511 65" Rear Projection...
The Mitsubishi Diamond Series WS-65908 does not power up. The troubleshooting code is 2-4
1blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
If it is 2,4 you have a problem in the vertical circuit and I would suggest you first look for any signs of glycol there.
Let me know if you need more information.
SD TECH
Oct 01, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I have a Mitsubishi WS-65511 with error code 22. I have been to http://www.tvrepairworld.com/mitsubishi_repair_kits and to TVrepaitkits.com and have no clue which kit I need, please let me know which...
You need a convergence repair kit - blink code 22 is almost always a convergenc issue. Sometimes it will look 3D and sometimes it will not show any video and have a 22 error code. TV Repair Kits has what you need.
May 17, 2011 | Televison & Video
Mitsubishi ws-65511 tv won't turn on
If the green power light on the front comes on for a second or two and goes out: Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both. Power light will blink a two digit error code: 2 blinks, 2 blinks, pause and it will repeat several times. Let me know if you find a error code and I will tell you what it means. IF this information was something you did not know, rate this solution as very helpful as I do this here for free. SD TECH
Sep 07, 2010 | Mitsubishi WS-65511 65" Rear Projection...
We have a WS 65511 with an error code 2,2. What does it mean and how can we fix it?
I am a expert on these sets and have fixed hundreds of them.
2,2 is short protection and 97% chance one or both of the pico fuses that protect the convergence circuit are blown (bad).
Model indicated uses a single STK-393-110 convergence IC. The fuses and chip are on the middle circuit board which needs to be removed to repair the set. Total parts cost will be under 25 dollars---I use a seller on EBAY who has the chip and the fuses.
I have start to finish step by step instructions for this repair in this model as I have done it hundreds of times.
Soldering and some skill are involved in getting the board out and replacing the parts.
let me know if I can assist you or if you have questions let me know here.
If you decide to repost this question mark it "attention SD TECH"
SD TECH
Aug 05, 2010 | Mitsubishi WS-65511 65" Rear Projection...
My Mitsubishi WS-65511 won't turn on.
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Feb 22, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
370 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
