Question about Husqvarna 20" 60cc Rancher Chain Saw 460
My Huqvarna 460 chokes out at full throttle. I thought it was bad gas, emptied the tank and ran almost a full tank with no problem, the next day it has the same full throttle problem.
  • 7,733 Answers
Do you mean high rpms? do you try the 2 adjusting screws? one is for gas/air mix and other for high/low throttle.
Posted on Oct 13, 2010
Hi, I have a 13.5hp Briggs & Stratton motor which starts and will only run on choke slow rpms and mild smoke.
check the point where the fuel hose goes to the fuel tank
there is very fine filter in the hose that could be blocked preventing full fuel flow
only running on choke indicates insufficient fuel flow
Apr 02, 2017 | Briggs & Stratton Garden
1989 f250 460 engine fuel problem
if the fuel lines have any rubber fuel lines they could be sucking air. also try replacing the fuel caps, it may not be venting
Dec 02, 2013 | 1989 Ford F 250
Chech engine light is on
I was getting the same and found out I got some bad gas.
The computer could not understand so 2 tanks later till running badly and giving 460+134 codes... Ran till empty - got best gas I could find ** -> the KEY **-> Unplugged the battery for a full 20 minutes, checked every wire for grounding issue (none really found) --- everything is great now.
Mileageicon1.png went down for that tank but then came back to normal.
Nov 22, 2013 | 2000 Kia Sephia
Starts fine, run fine,for about 2 to 5 min.,then cuts off,sounds like it's not getting the gas.
I have a Husqvarna 125B same problem. Turned out to be a bad gas cap. Doesn't vent properly and starves the engine. I took the gas cap off of my Huqvarna weed eater and put on blower and blower worked fine,
Nov 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
19 hp Murray garden tractor won't run
no sounds like your carb needs a real good babtising! good look!
May 19, 2010 | Briggs & Stratton Garden
Craftsman Lawn Tractor will only run in full choke
When you had the carb off did you clean the low jet with a welding tip cleaner? This solves most lawnmower hibernation problems. Next year empty the fuel tank completely and spray a little WD40 or an eqivalent into the tank and plug hole.
Jun 20, 2009 | Garden
Car stalls, chugs, hard start
change fuel filter add 2 bottles heat tell fix ya bout me ok
May 23, 2009 | 2002 Buick Rendezvous
Craftsman gas leafblower
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
Husqvarna 20" 60cc Rancher Chain Saw  460 Logo
293 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
