Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Error code F-4 & F-3
I am recieving an error codes of F-4 & F-3 when I try to turn my oven and/or broiler on. Burners work. I've already unplugged the oven for 5 minutes. Does anyonew know what else I can do short of calling service? It's Sunday and no one is around until tomorrow. Thanks.
  • 6,784 Answers
F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Apr 02, 2009
Fix error code E1-F1 on kenmore oven...model-95802000
That us usually a fatal error of the control board unfortunately. the control may need replacing.
Sep 17, 2014 | Kenmore Kitchen Ranges
Frigidaire oven and broiler stopped working but clock andtop burners work
Hello Friend, this is Z. I am happy to assist you!
I see that both the clock and burners of your Frigidaire range are working but your oven does not bake or broil. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you!
Sep 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have a GE double wall oven. I have a F7 errot on display. I unplugged the ribbon cable and shortly recieved a F0 error code on both the upper and lower side of the display. I replaced the ERC. it...
The F7 error coode means either the ERC or touch pad is bad. Having already replaced the ERC,replace the touch pad(the part w/the ribbon cable)
Gene
Aug 04, 2011 | GE Ovens
We cleaned my kenmore elite oven. now it won't work. when i try and turn it on i get an F23 error. do you know how to get the oven/stove working again?
Error code F 23 indicates the control detected a problem with the communication link or can be generated as a result of irregularities in the power supply or usage.
  • The error code F23 can often be resolved by removing power to the appliance for a minute and then restoring the power.
  • By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
  1. Unplug the unit or turn the circuit breaker off for 60 seconds.
  2. Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
  3. Check to see if the error code is still displayed on the range.
  4. Run the appliance in the cycle that initially caused the error or attempt to turn on broiler.
If the error code is displayed, then service is needed. The unit should be inspected by a qualified appliance repair technician.
Should you choose to use Sears, the number to schedule a repair tech is: Sears Repair Department 1-800-469-4663.
Nov 23, 2010 | Kenmore Ovens
The oven on my magic chef range does not work..broiler and burners ok ,,,get a F1 code and beeping noise ...model number 3488VTV
Hi hockeyhoskin,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Dec 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Broiler does not work!
rEPLACE BROILER ELEMENT. LOOK INSIDE OVEN, FIND SCREWS ATTACHING ELEMENT TO BACK PANEL. TURN OFF POWER. REMOVE SCREWS, SLIP OFF WIRES.
Oct 21, 2009 | Kitchen Ranges
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
hi there,
can you provide the model # off your stove please?
Sep 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Error code on the cook top.
Hello
A similar think happened to my wall oven and after many frustrating attempts, I just unplugged the oven for about an hour and when Plugged back in it had reset itself.
Eddie Rentas
Tupper Lake NY
Jul 14, 2008 | Cooktops
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
220 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
