Kenmore Elite 27086603 Washer...Machine becomes unbalanced and will stop spinning even with no clothing inside.
  • 5 more comments
  • Eddie Francis
    Eddie Francis Oct 13, 2010
    Sears Kenmore 110.27086603 Machine becomes unbalanced and stops spinning when it gets to the spin cycle. This happens with or without cloths in the machine.
  • Eddie Francis
    Eddie Francis Oct 14, 2010
    I have changed the computer because the old one failed giving me the F1 code and them shutting down. I had the balancing problem before I changed the computer. I was hoping by getting a new computer with updated software, would also solve the balancing problem but it did not. The basket seems to turn freely and the tub foats freely on it's spring hangers. Is there anything else I can check?
  • Eddie Francis
    Eddie Francis Oct 15, 2010
    I have changed the computer because the old one failed giving me the F1 code and them shutting down. I had the balancing problem before I changed the computer. I was hoping by getting a new computer with updated software, would also solve the balancing problem but it did not. The basket seems to turn freely and the tub foats freely on it's spring hangers. The hangers are not broken or detached. Is there anything else I can check?
  • Eddie Francis
    Eddie Francis Oct 16, 2010
  • Eddie Francis
    Eddie Francis Oct 21, 2010
    Hi Jahn27, Your solution sounds like the best way to go. I checked everything else I think. Where should I make the holes in the balance rings? The top ring sounds like it has water in it. Where should I make the holes in the top ring and where on the bottom ring?
  • Eddie Francis
    Hi Jahn27, Your soution worked. I can't thank you enough. But I'll say it one more time THANK YOU. I pulled out the basket and found that both the top and bottom balance rings had a good amount of water in them. I drilled 6 small holes evenly spaced in each ring to drain them. I'm glad you had me pull the basket because the driveshaft and the bearings in the basket were dry and starting to rust. So I lubed them while I had it apart. I reassembled everything and it works fine now. Just like the day I first used it. Thanks Again, Eddie2300
  • Eddie Francis
    Your solution solved my problem. Thank you Jahn27.
    President:
  • 1,554 Answers
Take the basket out and check the balance rings for water accumulation. Punch small holes through the balance rings to drain the water if there's any.
Please make you accept this post if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful or non-informative it is. Accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 16, 2010
  • 1 more comment
  • Jahn27
    Jahn27 Oct 21, 2010
    You can make holes anywhere you want on the balance rings. The sole purpose of the holes is just to drain the water so it doesn't matter where you put the holes.
  • Jahn27
    Jahn27 Oct 21, 2010
    Feel free to update me.
  • Jahn27
    Jahn27 Oct 21, 2010
    Please
    make sure you accept my solution since it solved your problem.
    Genius:
  • 1,416 Answers
HELLO,
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Here bare likely problem of the washer and their solutions below,
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • hope this help ?
    Thank you and thanks for visiting fixya.
    Posted on Oct 15, 2010
    • Oloyede Monsuru Oct 16, 2010
      HELLO,
      If
      your Kenmore Elinte washing machine does not agitate, spin or drain, you have a
      problem that needs fixing.
      The average do-it-yourself offer can do this job without hiring the professional technician. Each problem indicates a
      separate repair, but while you have the washer apart, it never hurts to
      check things while the back is off and the parts are off the washer.
      please exercise caution and make sure that the washer is unplugged and the water is off before you begin.
      INSTRUCTION AND MATERIAL NEEDED TO CARRY OUT THIS FUNCTION
      • Screwdriver
      • Needle-nosed pliers
      • Wire
      • Garden hose
      • Bucket
        Washer Won't Drain
      1. 1
        Check
        the drain hose to see if anything is plugging it. Sometimes small
        pieces of material go out with the wash water and become lodged in the
        drain hose.
      2. 2
        Open
        the access panel in the back by removing the screws and taking off the
        back panel. Remove the drain hose. this is usually held on with a
        clamp, collar or clip.
      3. 3
        Use
        a pair of needle-nosed pliers to remove the obstruction. If the
        material is further into the hose, you can use a sturdy piece of wire
        with a small hook bent at the end. Stick this into the hose to try to
        pull the obstruction out. If you still can't reach the obstruction,
        disconnect the entire hose and force the obstruction out with a water
        hose using the jet spray.
      4. Washer Won't Spin
      5. 1
        Check the pump or pulley if your machine doesn't spin. Sometimes the pump may be frozen or stuck.
      6. 2
        Remove the screws from the back access panel of the washer and remove the back panel.
      7. 3
        Remove
        the pump from the washer by unsnapping the retainer from the pump using
        a screwdriver. Remove the hose clamps and disconnect the two hoses one
        at a time. Have a bucket handy, because the hoses may have water inside.
      8. 4
        Rotate
        the pulley by hand. If it does not move easily, then you will need to
        replace this because it is frozen or stiff. Also, check the belts to
        make sure they have no tears or damage. While the pump is off the
        machine, continue to the next step to check the motor couplings. When
        these become bad, the washing machine will not agitate.
      9. Machine Won't Agitate or Spin
      10. 1
        Remove
        the pump and drive motor. You will find two plastic and one rubber
        motor couplings. One is located on the drive motor and the other is on
        the gear case with the rubber coupling between them.
      11. 2
        Pry
        or break the old couplings off with your screwdriver. Replace with new
        couplings. Simply push one onto the shaft of the gear case and press
        the second one onto the shaft of the drive motor.
      12. 3
        Line up the holes of the rubber isolation coupling with the studs in the coupling. Push the rubber isolation coupling in place.
      13. 4
        Push
        the isolation and coupling on the drive motor making sure that the
        holes line up with the studs on the other coupling on the gear case.
      14. 5
        Reinstall
        the drive motor and then snap the pump in place with the retainers to
        hold it in place. Reconnect the hoses with the clamps and snap the.Put
        the washer back on and screw the back in place. Position the washer
        where you had it before and plug the washer in.
      Hope this help?
      Good luck and thnaks.
    • Washing Mach... Master
    • 8,220 Answers
    This washer has 4 rods that hold it in suspension. One of them 4 rods might be broken or simply jumped the track. I have a service manual that is not your exact one but it shows how to get into the machine so you can check them rods. TECH MANUAL
    Posted on Oct 14, 2010
    • Dan Webster
      Dan Webster Oct 15, 2010
      Did you check those damping rods attached at the base?
    • Dan Webster
      Their is 2 kinds of movement the tub as you know is supported by 4 rods. The lateral movement is maintained by dampers attached from the base of the tub to the floor of the machine. Have you checked those?
    • 347 Answers
    1) There's a piece of clothing stuck between the inner basket and outer tub.
    2) The tub is not floating freely, usually because it's seized to the drive shaft by rust and crudus; FYI: this condition is almost always caused by using non-HE detergent in this washer. Also, be aware that, if this is the case, it can be very difficult to remove the basket from a badly corroded drive shaft, could even be a two-man job. And be careful you don't wrench your back
    3) Their is a updated machine control unit (computer) with new software that also helps minimize this concern
    • 2,382 Answers
    Hi, if your washing machine is unbalanced and stop spinning without clothes inside, then you have a problem with the internal components of the machine which can most likely be the machine drum or the belt and in most cases you need to replace both. If you are not technically inclined, please call in a service man to fix it. And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
    Posted on Oct 13, 2010
    Why does it always become unbalanced in spin cycle?
    how confident are you to get inside it? Check the balance springs and shock absorbers.
    Normally it is two simple things.
    First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
    Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
    Dec 26, 2015 | Washing Machines
    My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
    That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
    Jul 29, 2008 | Whirlpool Washing Machines
    High speed spin vibration and knocking
    This indicated the load in the washing machine is unbalanced. Open the machine and move the clothes in the drum so it is evenly distributed in the drum.
    Feb 05, 2012 | Kenmore Elite HE5t Washer
    My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
    If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
    The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
    The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
    Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
    Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
    Thanks
    Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
    HI There
    Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
    It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
    Let me know how this goes and thank you for writing to fix ya.
    Best Regards Richard
    Jan 07, 2010 | Kenmore Washing Machines
    Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
    Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    Vibration of wash machine
    Hi!
    Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
    Please do accept this solution and revert for further assistance.
    Thanks
    Rylee
    May 22, 2009 | Danby Washing Machines
    It makes buzzing noise and doesnt work
    click the link http://www.repairclinic.com/0088_11_1.asp#Level1_5
    Dec 11, 2008 | Kenmore 24902 Top Load Washer
    Noisy Spin Cycle
    hi there,
    Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
    Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
    Washing Machines Logo
    163 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
