Question about HP C6280 All-in-One Printer
Hp c6280 Ink cartridge problem: "The following ink cartridge(s) appear to be missing or damaged". there is no advice on which one. This happened when I replaced a low cartridge. I have powered down, unplugged power and usb, waited five minutes, and replaced all ink...same problem
    Problem Solver:
  • 10 Answers
I figured out the problem with my printer. If none of your ink cartridges are detected (missing) then follow the install steps below.
1. Turn on printer
2. After printer declares cartridges missing open the printer and remove the cartridges (advise putting a piece of paper under the cartridges to catch any ink that spills).
3. Turn off the printer (keep the top of the printer open)
4. Turn on the printer (still with the top of the printer open)
5. After the printer declares the cartridges missing again install the cartridges (while the printer is powered on). Close the top of the printer.
6. The printer should begin to cycle the ink into the printer and back out to the ink reservoirs.
7. After the ink cycle the printer should display genuine ink cartridges are installed
8. Make sure paper is in the tray so the printer can perform an alignment.
9. Everything should be ok after that.
Chad
Posted on Oct 09, 2014
  • HP Master
  • 7,733 Answers
Screen says "the following ink
I am having the SAME problem!! The cyan color for some reason!!! All of these are BRAND new HP ink cartridges!! Have you figured out how to fix this??
Feb 21, 2011 | HP Photosmart D7560 InkJet Printer
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink cartridge problem( s) appear to be missing or damaged
hi there,
Ink cartridge Problem
Cause : The indicated ink cartridge(s) are missing or are damaged.
Solution : Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-one, the ink cartridge contacts might need to be cleaned.
IF there is no ink cartridge missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Replace the ink cartridge.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 26, 2009 | HP Photosmart C6280 Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Not sensing the ink cartridge
In this scenario you should check with a new set of black cart or you can try by cleaning the cart with a lint free cloth. and try with resetting the printer as well. if it doesnt work then printer might have gone bad
Oct 21, 2009 | HP Photosmart C6280 Printer
Ink cartridge cannot be used after initialization
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
Sep 21, 2009 | HP Photosmart 3310 Printer
HP Photosmart C6280 "Ink System Failure"
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 26, 2009 | HP Photosmart C6280 Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
HP C6280 All-in-One Printer Logo
350 people viewed this question
Seeker5211
Seeker5211
