Question about McCulloch 2000W Inverter Digital Generator # FDD210
McCulloch 2000W Inverter Digital Generator # FDD210 runs fin but voltage too high , 160-200v .
  • 7,733 Answers
Download a manual at ->link.
Posted on Oct 13, 2010
Burning smell
What is the wattage of the device you are trying to run? Its possible that its too big for the inverter and its running hot.
Feb 09, 2014 | Whistler 2000w Power Inverter
Instuctions on how to start mcculloch generator 1800 w
I have one.. great little unit.. very reliable..
I am a wannabee diy guy.. so good luck
1 assuming sparkplug is good / in / /newish??
Fuel needs to be filled.. I suggest premium only (less residue if it sits for long.)
fill oil.. top up..
d/c electric plugs
then
togle ignition switch to on
turn fuel cap to on
turn fuel switch (sw) to on
move choke to start if engine is cold start.
pull starter cord ..
good luck
ps.. I have learned to run engine dry of fuel after use. turn off fuel (sw).. this empties carb.. You may have to pull starter cord a few times with next start to bring the fuel down..
Sep 24, 2010 | McCulloch 2000W Inverter Digital...
I have small portable generator with 220 vac in the philippines and a 12amp 12 v ac to dc converter. can i connect my 1000 w inverter to produce 120 vac becouse i dont have the batteries yet to run the...
no these are made to run off a batteries the 12 volt supplied from the gen is for charging batteries only and if the engine for starting the gen set has a battery their usual to small to run then their made for car style batterers.
hope this helps
Aug 14, 2010 | Vector 2000w Power Inverter
When my batteries run low on power the generator starts up. Most of the time the system works perfectly, but lately the inverter will click and keep clicking and the batteries will not charge, then the...
please check the voltage your generator is supplying to the to the inverter because a high voltage and frequency can make the relays in the inverter to make clicking sounds,and also do not allow your inverter batteries to run completely low before you charge it
Jan 06, 2010 | Xantrex Technology Trace Series Inverter /...
McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Apr 11, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch  2000W Inverter Digital Generator # FDD210 Logo
549 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
