Question about Microsoft Windows 98 for PC
Nothing is working! I need help
Ok I have a 98 Dell and it wont do anything... when i start it up, it gets to the Dell screen and then it goes to a black screen w/ a little flashing bar in the top left corner. It doesnt respond to anything u press on the keybord except to restart it...Before, i tried to delete everything on the c drive using the boot disk... and it gave me troubles... i cant remeber what it said be cause now the boot disk doesnt do anything. And so my dad tried to fix it by putting every floppy disk in and doing watever to see if it worked. And I think its really screwed up now... when I hold CTRL down to open the windows 98 startup menu... it says ERROR 0210:Stuck Key 03DT. press to resume or for setup. when I press esc to resume it goes to that black screen w/ that blinking bar... and doesnt do anything...
how do i get it to even get to the command prompt? or install an operating system(preferably 98)? This is like a mess around w/ computer and i really dont care about it, I just want it working again.
any advice will help. Thanks.. oh and could u like completly explane stuff becaus im only some what computer savy. thanks again.
  • 4 more comments
  • steelers86 Jun 02, 2008
    it is a Dell Dimension XPS R450
  • steelers86 Jun 04, 2008
    the service tag is HBT4X.
  • steelers86 Jun 05, 2008
    ok in the Boot tab there is a hard drive entry and when i press enter it gives me these options: 1. [Maxtor 91010D6- (pm)]
    or 2. [Bootable Add- in card]
    I didnt see any CDROM drive entries...
  • steelers86 Jun 06, 2008
    The date is right but the time is a little off...
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    I'm in Windy City but I just have to say - Steelers and Hines Ward --- Yessssss !!!!!!! Here we go Steelers here we go!!!
  • Edward Sheldon
    Edward Sheldon May 11, 2010
    "Stuck Key" error means just that. When the machine checked itself prior to booting, it found that a key on the keyboard seemed to be jammed. Happily, by causing this you're actually helping the situation. Remember where it says "Press DEL for setup"? Well, that's what you need to do. That will get you into the BIOS. When you first start the machine repeatedly tap the DEL key until you get into the BIOS.
    As you don't specify the model number of your machine, I'll need you to let me know the exact model number before I can talk you through the BIOS settings to change, so post that information on this ticket and I'll give you step by step instructions on which BIOS settings to modify to get your system up and running.
    Guru:
  • 859 Answers
You haven't received a response from Whisperwolf because our email notification system is down right now.
When you start your system and before your Dell screen shows, Press either the F2 or F10 screen. This should get you a System Bios setup screen. In this screen, see if there is an entry for your Hard drive and CDROM drive.
If you can get that far comment back and I'll check back here until our email system is working again. The fact that your computer is not responding to your CDROM is not a very good sign and your computer may have been starting to fail with the first of errors you received and is now at complete risk.
Regards,
Worldvet
Posted on Jun 05, 2008
  • Glenn Rogers
    Glenn Rogers Jun 06, 2008
    Hi, Back from an out of town trip and our email server is still down. There should be an entry somewhere for your CDROM device. I certain you don't see that so this helps.
    Did you check or can you check the bios setup screen again and see if the date and time is correct?
    Thanks again for your patience while our email alerts to we Experts is down.
    Regards,
    Worldvet
My dell inspiron 2400 won`t come on .it does not show anything on screen.
You first need to check the screen is working, disconnect the VGA/DVI cable from the monitor, then turn it on do you get anything on screen at all?
If that works reconnect the cable and turn it on, now boot the PC, do you see anything at all on the monitor?
No then check the cable/swop with new one or check the graphics card.
Yes but goes off after a few seconds, reboot and press the F8 key as soon as you hear the first beep, this should bring up a start menu, try safe mode, if that works load and windows it might be the graphics driver (has this been updated?) if yes try roll back to previous driver or you could even try system restore back to a date you know it all worked.
May 19, 2014 | Dell Inspiron 530s Desktop Computer
PLEASE NEED HELP WITH Dell Latitude D505 LAPTOP
shut your system completely down again plug it in to the charger and then restart the process of powering it back on as soon as you see the dell logo start pressing the shift key along with the f12 key if your hard drive is still intacked you should be taken to the start up menue select safe mode to start with. from there you should be able to get in to the program menue and you want to run system restore. if pressing shift and f12 does not get you in to the start up menue shut the system completely down again and just try hitting the f12 key to get in to it. if that does nothing either i am afraid you may have lost your hard drive.
Jul 15, 2012 | Dell Computers & Internet
My Dell Vostro 1520 wont boot. It begins to run then goes to my desktop but there is no icons nothing, just my desktop back ground. Nothing to click on Control alt delete will bring up the task bar but...
Hi. Press Ctrl+Alt+Del and select Task Manager... Click New Task and type in explorer.exe then press ok...
This should bring up your start button and the rest of the icons on your desktop...
^_^
May 18, 2010 | Computers & Internet
I cannot start-up a Dell Optiplex GX260 in normal mode
I recently had a problem that sounds similar to this - A virus was causing a fake validation window to pop up when I booted my computer and blocked all other functions.
Start your computer in Safe Mode and go to Start>Run>type msconfig and hit ok. Go to the Startup tab, make sure you can see everything in the Command column, and uncheck anything that doesn't sound fimilar. Hit ok then restart and see if the validation window pops up again after a normal boot. If it goes away you can prpbably clean away the rest of the virus with a simple virus/adware scan.
May 07, 2009 | Dell OptiPlex GX260 PC Desktop
Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Mar 15, 2009 | Dell Latitude D600 Notebook
Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
Feb 17, 2009 | Dell Dimension E310 PC Desktop
Dell inspron 8100 laptap with windows xp
Try booting with your windows xp installation cd in the drive. See if it will give you a repair or restore option when doing this. If it does not then it's possible your computer has a virus. You can check this by booting up with your anti virus cd in the drive and let it do a system scan. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Dell Inspiron 8000, 8100, 8200 Series...
Replacing a motherboard in a dell Inspiron 1000 laptop, and the screen not working
u need to reset the bios to factory defaults..this would fix your problem
Feb 06, 2008 | Dell Inspiron 1000 Notebook
Microsoft Windows 98 for PC Logo
116 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
