Question about Ryobi Garden
Ryobi Quickcut slasher goes on high idle and hunting all the time.
  • Ryobi Master
  • 7,482 Answers
Check your fuel filter in the fuel tank, if you have one.
It may need replacement or cleaning.
Also check your fuel tank for debris/trash and clean it out if necessary.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 23, 2010
Bought new carb for ryobi blower need to set up carby so it will start
Set both the high and low mixture settings two full turns back from the closed setting(full clockwise).. Set idle speed for all ahead full.
Start sucker and after a warmup throttle it down and then start adjusting the low mixture screw for fastest idle. Then lower idle some more but not to point where it starts to run rough. Then rev the sucker to high speed and adjust the high mixture for max speed. You may have to make a slight adjustment on the high speed to get a smooth transition from low speed to high.
Feb 09, 2017 | Ryobi Garden
Our 4710 tractor engine dies when slasher turned on.Why does this happen?
I take it to mean that when you engage the PTO drive the extra load to the idleing engine stalls
disconect the slasher and try engaging the PTO drive without load to discount an internal PTO gearbox fault if it doesn't stall check the idle speed fuel delivery system and airfilter any thing that can impact the power output of the engine
Jan 24, 2017 | Garden
Suzuki super carry 1.3 engine revs high low high low high low when clutch is put down engine revs very high
wow no year car stated nor a country x10 worse.
welcome to our USA forum!
the country with ZERO, carry cars. not a one. here
and due to that , no books here nor coverage at mitchells. either.
That is a G13 engine, (not m13) is my 1st guess.
Most Suzuki's with tiny engine and run a map sensors, not MAF
so is called SPeed Density system.
if yes, the that means ALL vacuum leaks cause fast idle.,
armed with that juicy fact, we know why it races.
you never said and actual RPM so no Tachometer?
only 2 causes. a huge vacuum leak
or unlikely the ISC stuck wide open with gunk inside, (clean it?)
ISC is idle speed control.
old suzuki's had man killler ISC software, my 91 did it.
and all others like it........
it would hunt idle like mad with any vacuum leak.(of any kind)
today this is very *******, this mode. (hunt)
toyata cost them $1billion in fines for this same deal.
but Clutch drivers have no problems with idle hunt, "skills"
what year/country.?
please showa photo of engine. ?
and win. a win/win
you win and I win not guessing all that.
fact 2 , is that that hunt tells me the ISC is moving fast.
so is not stuck. (99% says R3PO)
unplug ISC see the hunt end? sure.
the ECU has lost its wits. from..... this....
it sees a massive air leak (vacuum map readings ) and then (dumbblly ) hunts it like mad, (bad Firmware code) but real.
i can demo this is seconds hood up.
causes?
1: vacuum hose fell off.
2: same hose cracked.
3: brake booster diaphragm cracked, sucking air big time)
4: lots more,. even gunk under throttle plate blocking it open.
and more. lots more. can cause lots of vacuum leaks.
Dec 16, 2016 | Suzuki Cars & Trucks
Ryobi 725r carb adjustments
Zama Carb? Turn both low and high meter screws 2 full turns counterclockwise, and idle speed control to maximum. Prime unit and start motor. Run for about ten seconds and then turn idle jet (clockwise) for maximum rpm and then lower idle rpms - readjust idle meter as necessary along with idle screw. Then gun unit at high speed and turn high screw for maximum rpm. Go from idle to max and make sure there is a smooth transition. If not play a tad with the idle mixture screw till that is achieved.
Oct 22, 2015 | Ryobi Garden
Idle up down
hunting or surging ilde. name the 2 RPMS, low and high , is it hot or cold engine this issue.? 400rpm or 1000 or 2000 all are diff.causes.
no year, stated. so cant help.
but ill answer in the generic,
1: the ECU (got a carb,? )
the ecu controls idle speed at all times.
if not , there is a problem (you)
A: air leaks in the induction will make motor race at some point the ECU/ISC loses control. and hunts. trying hard to correct it.
b: egr stuck open idle too low, iSC cant correct it,, bad EGR.
c: engine EFI running way too leak starving for fuel so it hunts for 2 reasons < ISC hunting, and lean does that.
lean is gross power loss and opening throttle bogs the engine.
so is double bad. ISC makes it worse,
all this breaks down to 2 reasons.
1: ISC bad. in some way (gummed up. or restricted inside)
2: bad fueling or air leaks. vacuum leaks.
try answers , the hot cold question and the 2 speeds, of the hunt.
lowest rpm and highest of the hunted range of RPM.
Nov 23, 2013 | Honda Civic Cars & Trucks
My Ryobi cs30 weed eater tends to shut off after I release the throttle.
Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
Sep 06, 2010 | Ryobi Garden
Replaced timing belt, car now ''hunting'' Engine alert lighting??
Check the timing marks. Being one or two teeth off can advance the timing causing high idle.
Apr 20, 2010 | 2001 Hyundai Santa Fe
Daewoo Nubira hunts on idle revs high in between gear changes
I have a Daewoo nubira estate 2001. When starting the engine it hunts from about 1000 up to 2500 up and down. I have had the air control valve changed twice, the first time it fixed the problem, but the second time it had no effect. Is there any other item that can give this effect and how do I correct it Thanks.
Dec 12, 2009 | Daewoo Nubira Cars & Trucks
Ryobi 410r cultivator needs intital carb adjust ments,where do i start,how vmany turns on idle and high idle?
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
Jul 10, 2009 | Ryobi Cultivator
Garden Logo
134 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
