Question about Honeywell Heating & Cooling
Our honeywell airconditioning system is not getting cold. what is the problem?
  • Honeywell Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Oct 13, 2010
What can make the screen go off and the heat and airconditioning not work
Sounds to me like a breaker has popped. In the main power panel, see if one of the breakers is in the center position.
Nov 27, 2014 | Honeywell Programmable Thermostat Heater
Air conditioning does not get cold
If the A/C comes on but simply does not get cold, you will have to "charge" your system. As long as there are no leaks and no other problems, this will fix your system.
I hope this helps,
--Robert
Oct 29, 2014 | Pro Tools 1996 Geo Prizm A/C Condenser
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Aircondition not cold but rear aircondition seems cool only.
Check for the refrigerant charge. You may have a leaking system.
Oct 29, 2012 | 1992 Toyota Previa
Airconditioning problem on 92 cavalier
Your Orifice tube is probley clogged and needs replaced i wouldnt recomend this be done by someone not trianed to do tho also with new laws regarding freon unless you have acess to a reclaimer it is illegal to do becuase entire sytem has to be drained to get to tube
Jan 12, 2010 | 1992 Chevrolet Cavalier
I have an older square mercury Honeywell thermostat in my apartment. Furnace works fine in the main house using same model Honeywell thermostat. There is no heat coming from the apartment baseboards. I...
should have 24 volts @ t-stat. if tis is a boiler system it could have air in the zone that stays cold. bleed the radiator out and this should get the heat into the area you want.
Dec 06, 2009 | Honeywell Programmable Thermostat Heater
Airconditioning will not come on
And if what jumptrout51 said does not work, remove the thermostat to expose the wiring and place a jumper between (R) and (Y).
May 24, 2009 | Honeywell Heating & Cooling
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
I have a York Central airconditioning system in my house. This morning I put on the airconditioning at 19. The house temperature reads 25. It has not gone down at all from 25. I put my foot over the ducks...
Make sure that the outdoor unit is on. If it is on, then check to hear if both the big black compressor is running as well as the fan. If both are running then feel the fat copper pipe that comes out of the unit. If it is not cold and sweaty then your system is probably very low on refrigerant. If the line shows evidence of icing, it could still be a little low. Although icing can be the result of 4or 5 other problems as well.
Jun 26, 2008 | Heating & Cooling
Heating & Cooling Logo
90 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
