Question about Bissell 5770 Healthy Home Bagless Upright Cyclonic Vacuum
The 1st time i used the vac the brushes are not turning
    Problem Solver:
  • 14 Answers
Is the grey "brush"button pressed depressed? This vacuum requires the button to be in the down position to run the brush.
Posted on Nov 04, 2010
  • 78 Answers
Hi there Vaccum Guru from VacuumSpot.com.au here. Wow that is ****, however it's just not your problem. Take it back to the place you bought it from and ask them to replace it. Bissell are a good machine and have great backup, this should not be a problem.
Hope this helps :)
Posted on Oct 14, 2010
How to remove brushes on a hoover f5887-900 steam vac
Take off both tanks, then turn the steam vac over. Using both hands, pull evenly on each end of the brush block. They will pull straight out. But usually it isn't necessary to remove the brushes. Usually the problem is a blocked screen.If you look at the vac from the front of it with it turned right side up, there is a little window. Pull that off and using your fingernail, clean off the lint. If your model doesn't have a window that you can access, look underneath, near the brushes for a red plastic frame, pull down and it will expose the screen. Hope this helps.
Aug 18, 2014 | Vacuums
My hoover Model F5858-920 bushes stop turning how can i fix it?
1. Check to be sure recovery tank is on right. This is the problem 99% of the time the brushes use a turbine powered by the suction.
2. Check to be sure the brushes are set to "on" if it has that option. And that the screen filter on the front of the machine is clear.
3. Check the brush block by pressing the 4 tabs holding it in place under the machine. It will slide out. It should turn easily. If the tab to turn them is broken they will not work either. This is what they should look like:
http://www.vacuummedic.com/product.php?id=206
4. Place a screwdriver in the socket that turns the brushes, it should turn slowly but fairly smooth. It should not make any grinding or foul noises while turning or if it is frozen solid it is bad. This is the replacement part for that:
http://www.vacuummedic.com/product.php?id=229
The Vac Dr.
Sep 09, 2012 | Hoover Steam Vac Carpet Cleaner Spinscrub...
My eureka central vac power brush turns off when pushing forward than back on when pushing back. Ever seen this before?
Yes I repair them all the time. What that means is that the connection of the hose handle to the power brush upper wand is loose. This can happen over time with use. The connection just loosens up. Do you have the exact model of the power brush?
Nov 22, 2009 | Eureka 1810 Central System Vacuum
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Premalite vac brush stopped turning
Not familiar with thi sbrand, but a reset is for when the brushes get jammed pr stalled, it will trip the reset. Make sure that the brsuh roll turns easily, also for a broken belt and/or bad brush roll. Some resets are for when the vac motor over heats, it will trip saving the motor. Usually this is for a jammed brush roll or a clog.
Apr 23, 2008 | LG Electronics Premalite Vacuum Bagless...
Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Jun 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell 5770 Healthy Home Bagless Upright Cyclonic Vacuum Logo
80 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
