Question about Milwaukee 5345 21 1 3/4 Inch Spline Drive Rotary Hammer
I bought a used Milwaukee rotary hammer, model 5341, it was working good, then I blew a breaker out in the garage. After that it wouldn't work at all. I pulled it apart, got the motor to work without being attached to the hammer unit. I put it back together it didn't work. Took it apart again, and now I can't get the motor running at all. Does show power getting to the motor contacts (brushes ?) and Plate ? on one side..... maybe new brushes or armature required ? Any help would be appriciated.
  • Doctor PC
    Doctor PC Oct 13, 2010
    Seems like the power button is burn.
  • Dan Lichtner Oct 15, 2010
    I jumped power over the switch and the motor works, I have ordered a new switch, thanks.
5 Suggested Answers
  • 123 Answers
SOURCE: I have a Rockwell 616 Rotary Hammer. Where Can I
The manual I do not know but the Rockwell 616 uses a 9/16" Hex Shank. You can got www.icscuttingtools.com for a list of available bits. The bits are commonly known as Skil 728 Hex Shank. You may be able to find some locally where you are. I hope this helps. Let me know.
Thx
Posted on Aug 01, 2009
rowdy45176
  • 2176 Answers
SOURCE: my milwaukee 5316 rotary hammer drill wont
Could be a couple things, do you have the selector in the rotation mode, also there is an internal clutch that might have broken or the splines on the spindle might be rounded. If it is the clutch you would have to take it in for repair, it is extremely tricky to work on. Take the bit out (make sure you are using the right bits for this tool) and look at the splines to check their condition. Let me know if I can help more
Posted on Aug 25, 2009
  • 969 Answers
SOURCE: DeWalt 567 rotary hammer won't hammer
If still under warrenty local Dewalt store will repair. Total rebuild $99.00 on most tools.
Posted on Nov 07, 2009
rowdy45176
  • 2176 Answers
SOURCE: Does anyone know where I can get the schematic for
go to Milwaukeetool.com and under service type in your model number and date coded on the nameplate and you can download a breakdown and instruction manual for this tool.
Posted on Dec 22, 2009
Need Parts List And Service Guide For Kango 990/950 Breaker
If these are the original Kango kangos then you are out of luck. They have been obsolete for many years now and no parts have been manufactured for a long time. The name was bought by DeWalt and they didn't do much with it. The Kango name is now ownd and used by Milwaukee, but there machines do differ alot from the originals. There were a few main models and the main mid sized breakers were the 900 (hammer only) and 950 (rotary hammer) There were a few facelift/variations of each (K, X and B I think) and they did use a couple of different sized seals/pistons/cylinders.
If it is one of the Milwaukee models you can look up diagrams here...
http://www.milwaukeetool.com/
Apr 24, 2012 | Hammering
WE NEED INSTRUCTIONS. We can't make this thing drill.
if this is a Milwaukee drill, go t Milwaukeetools.com and type in the model number and you can download an instruction/owners manual. If not give me the brand and I will try and find one for you.
May 06, 2010 | Milwaukee 5321-21 Rotary Hammer
Bought a 5378-20 Milwaukee hammer drill used - what are the settings 1 and 2 for? No instruction manuel. thx
one setting w/hammer is for chipping,breaking up stuff.other setting w/hammer and drill symbol is for drilling in masonary application's
Apr 21, 2010 | Milwaukee 5321-21 Rotary Hammer
I need a parts manual for a milwaukee 5316-21 rotary hammer drill , where can I get one?
Go to Milwaukeetool.com and look under parts manuals. Type in the model you need and all the electrical/parts drawings will come up. You will need the serial number as well to get the most current drawing.
Feb 12, 2010 | Milwaukee Tool Milwaukee Hammer Drills 1 -...
I have a 5321-21 and it doesnt hammer milwaukee
If everthing turns on and there is no grinding in the gearbox, the unit most likely need and overhaul. Any Milwaukee service center will be able to perform an overhaul for you, or they can sell you a tuneup kit that has all the parts you need.
Jan 09, 2010 | Milwaukee 5321-21 Rotary Hammer
Remove broken drill bit
soak the chuck area real good with W/D40 or similar,position drill so lube doe's not drain .let sit for awhile, then turn upside down and gently whack it about, worked 4 me,
Oct 04, 2009 | Milwaukee Tool 1 - 1/2" SDS - max Rotary...
My milwaukee 5316 rotary hammer drill wont spin,just hammers
Aug 25, 2009 | Milwaukee Tool Drills
Lost my manual for the milwaukee rotary hammer drill, Model GAT serial number 776A196160.Can I download a free copy?
http://www.milwaukeetool.com/PartsAndService/DownloadManuals/Default.aspx
That is NOT a valid Milwaukee Model #, but the link above will give you the manual you want if you enter the correct Model #..
Aug 05, 2009 | Hammering
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
LOOKING FOR A MANUAL & INFO
Milwaukee now owns Kango, unfortunately I believe the 950sv is the old style. Parts are no longer avail. I have about 20 of the breakers. It is really too bad, they were great machines.
Jan 15, 2009 | Electric Demolition Jackhammer
Milwaukee 5345 21 1 3/4 Inch Spline Drive Rotary Hammer Logo
146 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
