Question about Goodman Heating & Cooling
My coil froze up last winter. What would cause this to happen?
  • Goodman Master
  • 43,501 Answers
Air conditioners that run in cold weather need special equipment installed to allow them to run in cold weather. It can be done by experienced techs.
You need to find the right guy that knows how to do it and then spend the extra $$$ to get the A/C to work right...
heatman101
Posted on Oct 13, 2010
Can you winterize a Tassimo
The best thing to do would be run some alcohol through it before you leave. The alcohol should be ethanol. That would absorb the water, wont be toxic and will not freeze
Apr 07, 2014 | Braun Tassimo Coffee Maker
Tip
Air Conditioner Ice Air Conditioner Problem
If you are experiencing the problems caused when your air conditioner becomes a solid block of ice then you need to figure out the real reason why it does or is doing that.
There are a few things that can happen to cause this unpleasant happening.
  1. The air flow over the coil is choked off to the point where the coil starts to become to cool because not enough air is flowing over it to keep it warm.
    1. Check air filter, if dirty clean it. (This is a very common problem)
    2. Check supply vents in building to make sure enough are opened to allow air flow.
    3. Check blower motor to see that it is operating at full speed.
    4. Return air temperature may be too cool. (below 65F)
    5. The indoor coil it’s self may be plugged with dirt. Clean with a good indoor coil cleaner.
  1. The outdoor air temperature maybe to cool which makes the indoor coil run too cold.
    1. Install a head pressure control to keep the high side pressures up.
  1. The unit may be low in refrigerant. This is often the first thing that gets the blame for causing this problem. Actually it should be the last thing to check after all the other possibilities are thoroughly checked.
If you have a coil that is froze up to a chunk of ice, then you need to remove power to the outdoor unit. Allow the indoor fan/blower to run to try to move air over the coil and thaw it out.
After the coil is completely thawed, then restore power and determine the cause of the freeze up.
A heat gun or hair dryer can assist in the deicing process. Towels and a wet/dry shop vac can help to keep the mess to a minimum also.
on Jan 03, 2010 | Heating & Cooling
Engine froze up. now burns oil
Put new rings bearings and gaskets
Aug 05, 2012 | 1990 Honda Civic
Why are we all having the same problem the last two days?
What happened is that sony has changed the power of the laser that read's the blue ray discs. This is causing a lot of the disc readers to die.
Also recent games have been using the ps3's power to the max and is causing some of them to overheat.
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
Won't start
check the IAT(intake air temperature)sensor, if its bad may cause a no start situation and flooding,also check foe fuses to the ignition system and voltage to the coils
Sep 08, 2009 | 1998 GMC Jimmy
No start up
No its not. Bad valves are caused by dirty filers,dirty coils that cause liquid refrigerant to slug compressor and knockout the valves. Rus
Aug 17, 2009 | Ruud UAMB Air Conditioner
Capacitor is out? Compressor won't kick on.
yellow line from capacitor to compressor has nothing to do with coil freezing up. sounds like your low on charge again, dirty filter causing coil to freeze, no blower operation, dirty coil.if system low again you might want to start looking for a leak.
Apr 26, 2009 | Intertherm P3RA-036K Air Conditioner
Diagnostic Message: Ec ...
press the temp button, and then press the light button, that will change the mode of the tub.
Apr 15, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Heating & Cooling Logo
22 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
