Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
When the clean water tank is filled and set in the proper position the water steadily dumps on the floor when i inspected under the unit you can see the white rubber diaphram approx. 3/4" in diameter exposed and you can see what i assume to be the suction line for the clean water when the handle is pulled it appears that there would have to be another part here some sort of cover or something to assist the diaphram in holding back the water from dumping out of the tank until the handle is pulled`does anyone have any photos of the bottom of the unit or know where i can get this part any thanks is much appreciated Bill
  • wmwmsjr Jun 02, 2008
    Thanks for the responding don the websites didnt offer much in the way of getting the valve or even getting a look at it it doesnt appear that the valve is even there as i can see the rubber diaphram and the suction tube and thats all the area im refering to is right on the bottom of the cleaner in other words if you flip the cleaner over there it is anyways if anything comes to mind let me know and thanks again Bill
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=49925&thid=639852
Posted by wmwmsjr on Jun 02, 2008
when the clean water tank is filled and set in the proper position the water steadily dumps on the floor when i inspected under the unit you can see the white rubber diaphragm approx. 3/4" in diameter exposed and you can see what i assume to be the suction line for the clean water when the handle is pulled it appears that there would have to be another part here some sort of cover or something to assist the diaphragm in holding back the water from dumping out of the tank until the handle is pulled does anyone have any photos of the bottom of the unit or know where i can get this part any thanks is much appreciated Bill
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There is a valve under the water holding tank that is probably giving you a problem and it is replaceable depending on if it is underneath the water holding tank or directly under the water tank. I am going to give you some phone #’s and websites that you can order parts from or fell free to contact your local vac dealer in your area for service and or parts.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell carpet cleaner doesn't **** up water
Turn the selector on the side from tools to floor.
Oh yea, could also be the seal is missing from between the tank and the suction nozzle. Could also be the tank is not seated correctly.
May 23, 2010 | Bissell 1699 ProHeat Clear View Upright...
My Bisell Proheat will not dispense water to the floor but it will dispense through the hand held tool.
check the little nozzle that the water sprays from and see if they are plugged if not your element chamber may need to be cleaned
Mar 02, 2010 | Bissell 1699 ProHeat Clear View Upright...
Filling the cleaner
cleaner goes in little tank on side. Hot water only no soap goes in the big tank in middle
Jun 25, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat 2x won't release soap water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tyu8
Jun 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
My bissell 1699 pro heat clear view upright water
heatman101
y
Feb 26, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
78 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
