Question about HP PSC 1610v All-in-One Printer
Error message on printer
S starting to align, it stopped with a message stating "check the color ink cartridge". I have taken it out, put it back in 20 times. It is HP and it is not expired. Please help.--Valoree
    Novelist:
  • 85 Answers
Hi
A few Trouble Shooting Tips:
You can try the following before buying a new one:
Unplug BOTH printer cables for at least 1 minute and it will reset to factory settings.
Also check the elec. contacts are not dirty... clean them with alchol and cotton wool and also clean contacts inside printer where they make contact.
If your printer has been left unused for some time? and the inks have just clogged up? you can easily revive them with our Magic Inkjet Flush print head cleaning kit
Good Luck
Tinteiros (Ebay)
Posted on Jun 02, 2008
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Canon mp240 error code 5 does not clear with the holding down stop/resent, starting and stopping on button as explained in earlier advice
E 4 or E5 for PIXMA is ink cartridge not recognised by printer. Try to take out ink cartridge (one by one) and check the brass connectors (at cartridge and the printer ink holder). If nothing suspicious, put cartridge back gently in and close lock firmly. Normally have to do this 2 - 3 times. If problem still occurs a simple trick put a piece of paper (with a bit of thickness) before locking the ink holder. Detail tutorials available here. Problem is due to the cartridge and ink holder connectors not aligning properly between one another.
Jun 16, 2012 | Canon PIXMA MP240 All-In-One InkJet...
My printer doesnt make any print at all.
Can you copy a document under the glass? B&W and color?
Are you using Dell Series 5 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Aug 14, 2011 | Dell 924 All-in-One InkJet Printer
I have a Dell Photo926 printer. I just changed the color ink cartridge and it is giving me an alignment error stating remove tape from cartridge. There is not any tape on the cartridge. I have ran the...
Are you using Dell Series 9 ink cartridges?
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
You are using Dell Series 9 ink cartridges, correct?
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Apr 26, 2011 | Dell 926 All-In-One InkJet Printer
I am getting the following error message: Black/photo cartridge missing
Rick
Mar 06, 2011 | Dell 924 All-in-One InkJet Printer
The colour ink cartridge is not being identified. I have tried taking them out and putting them in again. I have powered it off and on but nothing is working. Any suggestions would be greatly appreciated
Rick
Jan 09, 2011 | Dell 924 All-in-One InkJet Printer
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
Have all-in-one HP 7130. get error message stating alignment failed. Problem started after I replaced cartridge ink.
Whenever you replace inks it will want to do alignment. Before installing new inks you should dab the bottom gently on a damp paper towel and see that all colors make a stripe on the towel. If any colors are missing during alignment it will always fail.
Nov 03, 2009 | HP Officejet 7130 All-In-One InkJet...
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
HP PSC 1610v All-in-One Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
