Question about Lexmark X1150 All-In-One InkJet Printer
Its not communicating with the computer will not print!!!!!
  • 144 Answers
Check that you are using the correct virtual usb printing port in your printer settings and swap it around if necessary and check if you can make a test print each when the test prints works you have got comms. dont forget to after each failed test to delete the failed file out of the printer que
Posted on Oct 13, 2010
How can I get my mac to communicate with my printer?
reinstall the printer driver from the manufacturers web site as a lack of communication indicates a driver problem
next click on the printer > properties>compatibility tab> click box and highlight operating system on the computer and >apply
Jul 24, 2017 | Epson Workforce 615 AllInOne Printer
Won't print. Power is on, cable attached, computer says it is going to print. Says there is no 2 way communication between the printer and ?
You must firmly insert the cables that connects b/w PC and printer or buy new connector. Or, you may reinstall the driver..
Oct 20, 2012 | HP Deskjet D4360 InkJet Printer
Printer will not communicate with the computer
1. Walk over to the printer and print a test page directly. The procedure for printing a test page will vary from model to model, so you may need to consult the user guide that came with your printer. For most network printers, you can print a test page by navigating the "Information" menu on the control panel and choosing "Print Configuration" from the menu. For many desktop printers, you can print a test page by holding the power button until the page begins to print. If you can print a test page from the printer, but not from the computer, you know there is a communication problem between the printer and the PC.
2. Remove the printer cable from the back of your printer and the back of your computer. After the cable has been removed, carefully put the cable back into place, making sure that the printer cable is tight. If your printer uses a parallel cable, be sure that it is fully seated on the back of the printer and on the computer. If you are using a USB cable for your printer, be sure that the tab is fully seated in the computer, and that the square end of the cable is firmly connected to the printer.
3. Power down the printer, the restart your computer. Click on the "Start" button and choose "Control Panel" from the menu. Double-click the "Printers and Faxes" icon, locate your printer, right-click on it and choose "Properties" from the menu. Click on the "Print Test Page" button to send a test page to your printer.
4. Look at the network card on your network printer to see if there is good communication between the printer and the network. You should see a flashing green light on the network card. If there is no light--or if the light is amber or red--the communication is not happening. To test the network communication, remove the network cable from both the network cable and the network port on the wall, then reseat the cable and check the communication again. If the problem remains, you will need to remove and replace the printer's network card.
Aug 10, 2012 | Lexmark X4650 InkJet Printer
Not communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Dec 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
Printer wont comunicate with Computer
Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect to your computer. Try to print again. If problem continues, you may refer to these articles in the Lexmark website:
- Communication Not Available' Error Message and Print Job Stalls in Print Queue - No Communications Error When Trying to Print or Scan
I hope these help. Thanks.
Feb 16, 2011 | Lexmark P4350 All-In-One InkJet Printer
Epson nx400: prints test page; doesn't print other things
If it prints a test page from the printer and not from the computer, then the issue is with the communications from computer to printer. If it is a net work printer, go to the c prompt and to a ip address ping and see if there is any communications.
Feb 05, 2011 | Epson Stylus NX400 InkJet Printer
Communication between Computer and printer
Re-install driver/software. Re-start computer. What does device manager indicate?
Jun 27, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark x5470
When you got this message were you trying to scan?
What I want you to do is a copy. Doing a copy will generally not require you to be hooked to the PC.
Scanning and Printing all require communication from the printer to the computer. Failure in communication can either be something on the computer, something wrong with the cable or rarely something wrong with the printer.
I'm assuming you have done the following:
1. Power off your printer and your computer.
2. Unplugged the power from the printer
3. Unplugged the USB cable from both the printer and the computer.
4. Reconnect the USB cable to the printer and the computer.
5. Plug the power back into the printer and make sure the printer is on.
6. Turn on the computer.
Those are general troubleshooting steps that can be done for any communication problem.
If you have done all of those try this:
Press and hold down the Windows key on the keyboard, and then type the letter R.
Type "devmgmt.msc" and then click OK on the Run dialog.
Find the item Universal Serial Bus controller.
Click the + sign next to the word Universal Serial Bus controller.
Do you see USB Printing Support?
Yes:
Right-click on USB Printing Support, and then click Properties.
Does the Device status say “This device is working properly.”?
Yes:
Have you tried uninstalling and reinstalling the software?
No:
Click the Troubleshoot button to try to resolve the problem.
Does the Device status now say “This device is working properly.”?
Yes:
Try your print again (might need to restart)
No:
Might have a problem with your Printing Support
No:
Let me know - if you have a problem with your printing support you'd really need to contact your PC MFG for help - but you can always try uninstalling the USB Printing Support and reinstalling it (only if you have your disks that came with your printer).
Sep 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Computer isn't communicating with my printer
computer is not communicating with my printer i unplugged the usb port i and i resart the computer
Aug 31, 2008 | Nikon COOLPRINT Thermal Printer
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
