Question about ADVANTAGE Waterway Executive 56 Frame Spa Pump Volute 3151220
Just purchased an executive 56 waterway pump. need to turn the volute to match existing plumbing. Do I just remove face plate, undo main bolts and reposition or is it more dificult??
    President:
  • ADVANTAGE Master
  • 1,378 Answers
It is actually easier...do not remove the face plate, just the thru bolts. Once all 4 are released turn the whole pump in the direction required and reinstall the thru bolts.
Done!
John
Posted on Oct 13, 2010
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Cant get face plate back on, for my Executive 56 Hot tub pump
these plates have notches that line up with the housing..it may be backwards or need spun a bit to"lock in"
Oct 26, 2013 | Waterway Pool & Spa
Remove wet end shaft on a 56 executive spa motor
if was leaking it ruined bearings in motor replace whole unit
Jul 29, 2013 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
Waterway model # pf-50-2n22c
The wet end of pumps come off this way.
  • Remove the face plate of the pump.
  • Put a large flat-head screw driver on the back of the motor on the shaft going thru the motor.
  • Grasp the impeller (with the screw driver in place on the back of the motor) and unthread the impeller counter clockwise.
  • If it doesn't unthread you will need to bust it off
  • On the back of the motor you will find 4 small bolts 1/4" size that run all the way through the motor and thread into the four fingers of the wet end.
  • Unthread those 4 bolts and you can then remove the volute from the motor.
Rod
US Parts Center
888-521-6183
Mar 14, 2013 | Waterway Pool & Spa
How could I remove the impeller to rotate the discharge.
You do not to to remove anything on the pump end to rotate it. Loosen the 4 motor thru-bolts at the end opposite the pump; they pass all the way thru the motor into the pump bracket. Once those are backed out you can spin the pump discharge into the position you need and reinstall the thru-bolts...done!
John
May 21, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
How do you remove the impeller from the motor shaft?
If the shaft seal has been leaking the impeller stem may have split due to corrosion. This makes it very hard to un thread the impeller. After removing the face plate, try sliding a screwdriver into the front of the motor thru the vents. You should be able to seize the armature from turning by doing this. Then use a large channel lock wrench and try and un screw the impeller CCW. If this doesn't work you have to break the impeller off. See my previous post.
Oct 16, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
Impeller replacement
The spacer plate (called a wear ring) should indeed be installed between the front plate and the impellor. The wear ring should be installed the correct way around, with the flat face against the front plate. Assuming that you're fitting the front plate correctly each time (it only fits on one way) there shouldn't be any issues. I can only assume that you have either fitted the incorrect impellor or it hasn't been tightened fully onto the motor shaft.
Hope this helps,
Regards,
Ian Kime.
http://hottub.synthasite.com
Oct 29, 2009 | Waterway Spa Pump Executive 56 Frame 2hp...
How do i remove impellor
The impeller in my 4 HP, 2-speed Waterway Executive High Performance 56 pool & spa pump has a brass coupling embedded in the back side. This coupling can be unscrewed from the motor shaft by keeping the shaft from rotating while turning the impeller in the reverse direction. Then the seal can be tapped out.
Oct 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Execetive 56 4hp pump
Looking at the face of the pump, the impeller unscrews by turning it counterclockwise. Also, for some strange reason, the 4HP pump gets a 3HP impeller; the rating is embossed, in very small letters, near the center of the impeller. The 3HP impeller part number is: 310-4200.
Be sure to change the seal: US Seal P/n: PS-1000.
Oct 20, 2008 | Waterway Spa Pump Executive 56 Frame 4hp...
ADVANTAGE Waterway Executive 56 Frame Spa Pump Volute 3151220 Logo
172 people viewed this question
Top ADVANTAGE Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an ADVANTAGE Pool and Spa Expert? Answer questions, earn points and help others
