Question about Brother MFC 240C All-In-One InkJet Printer
Sacnning my computer doesnt recognize the scanner but everything else
My computer recognizes the all-in-one unit model MFC-665CW. I can copy. I can with the unit.
I can print from the computer. But I cannot get the unit to send a scaned document to the computer, or if it is going there is no evedence of it.
Charles Aiken
aikentree@charter.net
Posted on Dec 12, 2008
REINSTALL SOFTWARE AND ALLOW IT TO FINISH
Posted on Jun 19, 2008
When I attempt to sacn I get the following error: The function you have requested cannot be performed because another program already has control of the device. If the program currently using the device,...
Have you tried restarting your computer and the printer? If not, restart both the computer and the printer and then try again, if there is no hardware issue with your printer, this will definitely fix your issue.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 29, 2011 | Office Equipment & Supplies
Scanner no longer communicates with the pc
Have your scanner turned on when you boot up your computer. Go to Programs, Acessories, Scanner and camera wizard, and it will give you directions if the scanner is not installed and recognized.
Aug 21, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
PC stopped recognizing Nikon Coolscan 8000
Ah Firewire ;) Have you tried reinstalling the firewire card drivers? Make sure you press the "delete driver" button if there is one/
Jun 17, 2009 | Nikon COOLSCAN 5000 ED Film Scanner
Escndv.exe problem connected with Epson scanner 4490 Photo
http://www.howtomendit.com/answers.php?id=64090
Go here: C:\Document
s and Settings\[username]\Application Data\EPSON\ESCNDV\ES0058
and delete any image files in that folder. The last folder might have a different number depending on your scanner. It should start working again.
If you can't see that folder - click on My Computer - in the menu click on Tools and select 'Folder options..." Click on tab 'View' and select 'Show hidden files and folders'
You should now be able to see 'Application Data' in Docs and Settings...
May 30, 2009 | Epson Perfection 4490 Photo Scanner...
When i set up the driver ,the scanner doesnt work
The driver is just a driver, you need to install the MP Navigator software. Canon classified it as a utility so look for it under Canon Utilities in your All Programs. If you cannot find it on the computer, install it from the CD or just do search for Canon MP Navigator and download it.
Jan 02, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Computer doesn't recognize scanner
maybe the cabel is broken, what type of cabel do you use for connecting to pc? if usb try to change the usb port, if this doesn"t work change the cabel. btw the scanner has to be started.
Dec 15, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Computer Wont Recognize Camera
if u r using xp try this option ..control panel> printers and hardware >scanners and cameras..and try installing the camera from dere keeping it connected...if this doesnt wrk ..chk if ur camera is in the 'mass storage memory' mode..can be found easily in the menu settings..and then connect....if still not recognised...search for the drivers on net
Sep 18, 2007 | Sakar 57482 Digital Camera
LS2208 scanner unrecognized by my HP notebook
It is not likely VISTA will run your scanner software as it is very old. However you could check program compatibility mode and set it to run as Win 95/8 Check compatibility in Start/Programs/Accessories or go to my Computer Windows Help[ and type compatibility in the search field But I don't think you will get far.
Aug 05, 2007 | Symbol LS2208 Handheld
Brother MFC 240C All-In-One InkJet Printer Logo
103 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
