Question about Craftsman Garden
Water pres comes out where the soap is to go in
  • turtlethomas Oct 14, 2010
    this is a presure washer water comes out where the soap is to go in instead of the sprayer
    I have changed all the valves the one that leads to the out hose and the one that has the screw adjuster on it can you show me a diagram of the one i should look at
    thank you
  • 43,501 Answers
I am assuming that you are talking about a washing machine here....got it in under chain saws though...
I think you will find that the holes to drain the soap are plugged up....then the water has no where to go but out over the top....
See if there is a clip that will release and let the drawer slide out so that you can clean it up....
wash everything you can out and make sure that all holes are open...
heatman101
Posted on Oct 14, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Oct 14, 2010
    All rightty then....that changes everything... :-)
    The soap on a pressure washer is pulled in by a venturi as the wateter flows by it creating an artificial vacum. To keep the water from coming back out there when it is not going through the hose to the wand there is a check valve. This check valve is either broken or has dirt stuck in it...
    You will have to find it and repair/replace as needed....each pressure washer is a bit different...but a one way valve at the end of the hose that pulls the soap in should not be hard to find...
    heatman101
  • D. Floyd Kolb
    D. Floyd Kolb Oct 15, 2010
    It would be the part number 32 in this picture...all those parts that make up 32 are a check valve....that is where your problem is...
    http://www.m-and-d.com/pdfs/Karcher/5958...
    heatman101
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
Tip
Fix simplehuman soap dispenser
Solution!!!!! to Simplehuman sensor soap dispenser with blinking red light no despensing of soap and new batteries. Rinse out soap with hot water. Fill reservoir with hot tap water. Use bulb end of turkey baster. Place on reservoir to form a tight seal. Force air into reservoir. Which will force the hot water thru the system unclogging the thick soap. Repeat this several times till clear of soap. Then turn on the unit and flush thru the rest of the hot water using the sensor till comes out nicely. Then fill with a thinned out soap. Good luck
on Jan 16, 2014 | Simplehuman Sensor Soap Pump ST1001
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
The soap dispenser on my price pfister kitchen faucet won't pump soap. It pumps, but no soap comes out.
Two things spell trouble for these poorly engineered units:water and thick soap...
Inside these pumps is a metal ball for
the check valve. any water in your soap
will corrode this ball, causing the pump
to lose it's prime...
Using soap thats too thick (like Dawn)
will cause the soap to harden around the moving parts and impede the pumping
action. Try a thinner soap, such as inexpensive pink hand soap.DO NOT
ADD WATER! (See above)
Hope this helps.
Dec 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Water from soap dispenser when spinning
Thanks this solution cured mine and my friends machine with this problem of water coming out of the soap dispencer.
Jan 12, 2009 | Washing Machines
Dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Nov 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
No water or soap coming out
the filter could be block under the flow indicator cap,
but water should still come out of the hose
Nov 07, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Oct 21, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Garden Logo
23 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
