Question about Ionic Pro CA500 Air Purifier
Machine is plugged in, the blue lights for Low Medium High light up, Clean does not, no sound at all from machine, very slight air movement. Have no idea if the machine IS working or not. Do not have manual, was purchased from online auction, listed as NEW. Your help is deeply appreciated. R. Singer
  • 1 more comment
  • exile389 Oct 13, 2010
    I do NOT have an Ionic Turbo Pro, it is model Model # CA-500. Plugged in only the Low/Medium/High setting light up, it skips past the 'cleaning' light which does not appear to work; there is no air passing through or from the machine. It sits silent, doing nothing with its little blue light on. It was sold as 'New'. Thank you for any assistance.
  • exile389 Oct 14, 2010
    mchaos, you have been so helpful. I purchased this 'new' on eBay and was ready to send it back with a complaint. I see from your comments as well as other experts who were kind enough to make notes that the machine is indeed working as its meant to. Please accept me thanks and appreciation, and I hope the fee is yours. Sincerely, Rs
    Yes, mchaos and others explained the machine is working. It did not come with a manual and there was nothing online to clear up my concerns, everyone was very generous and helpful. Well worth the small fee! Thank you to everyone.
    Guru:
  • 773 Answers
These machines are designed to make no sound at all. They work on ionic charged molecules in the air, which causes the air to move through it.
There will not be great deal of air movement through the unit. If you feel air moving, it is working.
Give it a week of running. Then pull out the filter rails. They should be coated in a film of dust. This means the unit is working as it should.
When the clean light comes on, it means it is time to clean the filter rails. So this should not be lit yet.
From your description, it sounds like this is working.
Posted on Oct 14, 2010
  • Don Reiman Oct 14, 2010
    I did not say you have a turbo. You said in your description, "slight air movement." Ionic air purifiers make No noise while operating. The cleaning Light will not come on unless the filter needs cleaning. The ionic purifiers only move the air softly. You will feel the air moving through it, but it will not be a lot. That is how they work.
Click on the link below to view the Ionic Pro CA500 owners manual:
http://www.ionicproturbo.com/images/IP_TurboPro_Manual.pdf
Posted on Oct 13, 2010
  • Anonymous Oct 15, 2010
    I didn't know there was a difference in the two, thank you for updating me!
Blinking 'Check Collector Cell' light
which model XL series do you have? There is obviously something shorted or arcing on the plates of the cell. look at the plates and see if they are laying flat and the wires are all still attached across the front of the cell. A loose, sagging, broken or bad contact on the end plates will cause the bad cell lights. clean off the area where the cell makes contact inside the unit. The metal strips that run across the ends of the cell make contact with the plates inside the cell and get their power from them, dirty contacts in any part of these contacts will cause the problem. Even a bad contact from the end cap to the plates inside the cell will cause this. Try wiggling the cell around, kind of push on it on edge to get the plates to shift slightly and clean the points where the plates touch the outer strips on the sides. Check for arcing with the lights turned off,
Oct 20, 2014 | Oreck XL Professional Air Purifier
No Medium Fan Speed
sounds like ur medium speed has gone out
Feb 20, 2010 | Air Purifiers
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze Professional GP series.....question regarding lights
red light will not go off what do you do or is it still working or not and the red light is just on
Apr 04, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
Dec 11, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Blinking blue lights
What is happening is this: the main electrical component is overheating and forcing the machine to turn off. When it cools, the machine turns back on. Yes, that is actually what is causing the blinking.
There is no solution for this as the main electrical component (a high voltage capacitor in this case) has failed due to stress. In my case, the machine worked for 2 months before failing. The only real solution is to have the unit serviced. However, as there is no service centers, we are all out of luck.
I believe this could be a class action law suit against sharper image for selling units built with components it knew would fail after a short period of time. They had hundreds of reports with this same failure and they knew the cause. Pressing the "boost" button too much causes extreme stress on the capacitor and shortens its life drastically. This capacitor is what provides the power to the ionizing wires.
Feb 02, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Problem
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Aug 05, 2007 | Sharper Image Ionic Breeze SI719 Air...
What does a blinking blue light indicate?
Jul 07, 2007 | Sharper Image Ionic Breeze GP SI720 Air...
The low button light is going out.
Oct 24, 2006 | Ionic Pro 901P2RIP04 Air Purifier
Ionic Pro CA500 Air Purifier Logo
334 people viewed this question
Top Ionic Pro Air Purifiers Experts
Thomas Perkins
Thomas Perkins
Brett Duxbury
Brett Duxbury
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
