Question about Alesis M1-Active MkII Main / Stereo Speaker
One of my speakers seems to cut out when I raise the volume and its not
clipping . when I ay raise the volume I mean on the hard disk recorder. The volume on the 620 is not quite half open
How to make it have sound again
Posted on Jun 30, 2008
Alesis 620 M1 active no power no light
You just fix the power supply and Brige and check the transformer
May 18, 2012 | Alesis M1-Active MkII Main / Stereo...
I lost the treble on both Alesis Monitor 1 speakers. The treble is good on the amp output toward the speakers. I'm thinking they went out one at a time and I didn't realize it until I lost the...
It's probably blown tweeters. But if you want to spend the money on a hipshot guess, try to find the the crossovers somewhere first; then find the readily available tweeters if/when that doesn't work out. Google "alesis monitor one MK2 tweeter".
You could test the tweeters by just removing one non-functional tweeter and wiring it directly to the speaker leads and with REALLY LOW volume containing NO BASS see if it makes any sound, which would prove it does/does not work.
Going forward, if the speakers sound stressed at high volume - THEY ARE. Too much power or too much distortion (overdriven amplifier) will kill speakers.
Sep 16, 2011 | Alesis Monitor One Mk2 Speaker
What would make the sound turn on and off repeatedly when I raise the volume past about 17.
well, if you have aftermarket speakers with no amp, the radio may not have the power the speakers need and it clips at that volume to protect for damage. if you have factory speakers, I don't know what it would do that, the speakers would blow before the radio would clip if they were factory because the radio would have more than enough power to push them.
Sep 19, 2010 | Alpine CDA-9827 CD Player
Alesis M1 active 620 woofer problem
There clearly is a fault in the sub's amp section. It's probably the main part that does most of the work. It will need to be replaced.
Mar 07, 2017 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 Active 620 studio monitor cutting out
I see from the manual there are several controls on the speaker that could affect the sound in the way you describe (gain, hi- and mid-boost, acoustic space). Why don't you compare the actions of each control with the working speaker as the standard and a test tone or FM noise as the source? It might help you to identify a specific internal function that has changed. After that, someone's going to have to crack it open and do surgery.
You might also try using the opposite input (TRS vs XLR) than the one you're using. It might reveal something.
Mar 13, 2010 | Alesis M1-Active-MK2 Powered Studio...
My alesis m1 active 620 monitors blue lite keeps blinking and duz not work
Thanks for following up...I took it to get fixed..$150.00 later it works..
Oct 04, 2009 | Alesis M1-Active MkII Main / Stereo...
Speakers are not giving out sound at all. It will randomly come and go. Seems to happen at raised volumes (above 10 on my system). The speakers do not crackle or give any noise.
if it is a factory radio then your factory amplifier is bad. if it is an aftermarket radio the outputs are clipping you possibly have a blown speaker ot too many speakers. then again the radio could just be about had it.
Sep 23, 2009 | Volfenhag ZX-862R Coaxial Car Speaker
Alesis 620 m1 active studio monitors sound cutting out
It could be a power problem, unless you have blown the driver ?, carefully pull out the power supply board, and look to see if anything looks melted, burned, or capacitors popped etc. Be carefull though as I do not want to be responsible if you get an electric shock, etc. preferably look and dont touch, just use common sense ;)
Feb 10, 2009 | Alesis M1-Active MkII Main / Stereo...
Raised volume cuts sound and gives me "overload" message
A couple of possibilities: Bad solder on power regulators (attached to main heat sink) or cooling fan may not be turning on when volume is raised.
Jan 16, 2009 | Audio Players & Recorders
Alesis M1-Active left speaker emitts a very high pitched wine that sounds like feedback
have your built-in amp checked for trouble. there should be trouble in the output stage feedback loop. this is something to be done by a repair technician
Apr 11, 2008 | Alesis M1-Active MkII Main / Stereo...
Alesis M1-Active MkII Main / Stereo Speaker Logo
171 people viewed this question
Top Alesis Audio Players & Recorders Experts
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
