Question about Toshiba (P000226820) Plug-In Module (Laptop) Floppy Drive
TOSHIBA LAPTOP PLUG
WHEN MY LAPTOP IS PLUGGED IN, THERE ARE TIMES WHEN I BARELY MOVE THE LAPTOP, AND IT SHUTS OFF. IM THIN
KING ITS THE PLUG IN THE LAPTOP. SOMETHING IS LOOSE, HELP!
  • canning4 Feb 08, 2009
    2 year old satellite m115---replaced dead 6 cell battery with 8? 9?
    cell because I thought it was battery problem. New battery never
    charged, have been having problems with plug in back (wiggling). Now I
    know it is much bigger deal, repair would cost probably be half the
    cost of new laptop. Having ac plugs in rear is a very poor design. Also
    I am on my 3rd power cord. Miss my laptop! -Lynn
  • 52 Answers
Your thinking is correct wiggle the connector in the back where you plug in the ac adapter and see if the charge light goes off and on, then you have a defective dc jack and will stop working altogether shortly. What happens is that over time the connections come unsoldered or one of the legs breaks. It costs about $75.00 to replace.
Posted on May 02, 2009
Toshiba Windows 7 satellite pro. screen goes
DO NOT OPEN/CLOSE THE SCREEN ANYMORE(or move it at all)
Your laptop is damaged from the hinges which is a pretty common issue
The only solutions would be to:
1) plug in a monitor
2) buy a new laptop
Sep 08, 2013 | Toshiba Computers & Internet
Toshiba laptop shuts down in less than 5 minutes when powering on /cleaned all the dust out and no change
The laptop will need to be dismantled to the motherboard level, remove the fan, heatsink, and blow out dirt and dust with compressed air. Next remove the old thermal paste with a paper towel and rubbing alcohol, including the processor and heatsink. Next apply a thin layer of thermal paste to the processor and heatsink and assemble carefully, and don't forget the fan, plug in to motherboard. Now if it turns out the fan is faulty it must replaced quickly, other wise you risk destroying the processor ic.
Apr 09, 2012 | Toshiba Computers & Internet
I purchased a Toshiba Satellite C655D-S5084 in late December, and after, NOT EVEN, 7 months later, I began having issues. The laptop ran FINE, and was fantastic, however... it was having issues charging....
Hi
I have seen this problem many times, and in every case, it has been a wire broken between the output of the charger and the plug that goes into the laptop. If your laptop has a "power connected" led, then that should give you the answer, assuming you don't have a voltmeter to test the output.
Mar 17, 2017 | Toshiba Satellite C655D-S5084 Laptop
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
I have a toshiba laptop, the cursor doesn't move, how can i fix it
unplug your mouse and then plug it in again if that doesn't work, un plug it and shut your computer down, then plug the mouse in and start up your computer with the mouse now plugged in. Mine acts up once in a while, you might need a new mouse. get more help for Toshiba Laptop Repair hope this helps you.
Feb 01, 2011 | Computers & Internet
Windows shuts down when card reader or camera is plugged into USB
Some software programs monitor for removable drives which are not used. When you plug in your camera or memory card or memory stick, It comes up as a removable drive. My wife's laptop with Vista Home Basic had a problem between her secure memory stick and InCD. BSOD would cause restart the computer when stick was plugged in. I temporarily disabled InCD and memory stick works. Funny, though, her machine had no trouble with her camera. Go figure.
Dave
May 09, 2009 | Toshiba Satellite A215-S4747 Notebook
Ac adapter light is solid green, but when plugged into laptop...
the most likely reason is a systemboard problem (the ac plugin port cannot changed independently for notebooks)
Mar 23, 2009 | Toshiba Satellite A65-S126 Notebook
Randomly Shuts Off
I think ur laptop goes to power saving mode.Right click on the desktop then choose personalize or properties if u have xp.
Then click on screen saver at the bottom click change power settings.Now if the power saver is checked then uncheck it and choose balanced in that change the timings as when it should sleep according to ur wish.
If u have any other problems please ask me..
Goodluck
Please don't forget to rate me as fixya..
Feb 06, 2008 | HP Pavilion zd8000 Notebook
Toshiba satellite 1135
There should be some loose connection or a broken power cord. You may have warranty for the laptop and accessories, replace immediately
Oct 27, 2007 | Toshiba Satellite 1135-S125 Notebook
Toshiba (P000226820) Plug-In Module (Laptop) Floppy Drive Logo
286 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
