Question about Apple iPod touch
How do i get my pass code off my ipod touch 8 gb
  • Apple Master
  • 7,482 Answers
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please rate me
Posted on Oct 14, 2010
Tip
How to remove songs from your iPod Touch 2
<p>The second generation iPod Touch, also known as the iPod Touch 2, was in storage sizes of 8 GB, 16 GB and 32 GB. Depending on the model, he may never need to remove songs to free hard disk space. If you find yourself in tight space, or low-end version 8 GB or more 32 GB mode settings, use iTunes to manually manage the songs on the iPod Touch. <br /> <p><br /> <p>1. Hook touch to your computer using the USB device. <br /> <p><br /> <p>2. Open iTunes. The program takes a while to read and display the name of his touch in the source list left. <br /> <p><br /> <p>3. Click on the name Touch the left in the source list. <br /> <p><br /> <p>4. Click the "Manually manage music and videos" box, located at the central, if not already selected. This mode is used for music from your iTunes library once the iPod touch in the library computer. <br /> <p><br /> <p>5. Click the "Music" option in a list of source Tap the left pane. Touch your music will appear in the center pane. <br /> <p><br /> <p>6. Click the number you want to delete. If you have multiple numbers, hold down the "Ctrl" and click on the numbers. <br /> <p><br /> <p>7. Right-click a selected song and click "Remove." <br /> <p><br /> <p>8. Click "Remove" to delete the song (s). <br />
on Aug 05, 2011 | Apple iPod touch
I need to reset my i pod touch
I'm posting two links for you: one for unlocking a your ipod, and the other for resetting your device to factory settings.
Good luck Forgot passcode for your iPhone iPad or iPod touch or your device is... Restoring iPod to factory settings
Sep 03, 2012 | Apple iPod touch Second Gen (8 GB,...
I have an 8 gb ipod touch that is now disabled because I can't remember the 4 digit code. The message on the ipod's screen says 'ipod is disabled. Connect to itunes.' The computer that I originally used...
connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
this process is all on the computer.
May 20, 2010 | Apple iPod touch
I locked my ipod and i forgot my code for it and i
get in touch with apple and they will reset it for you
Jan 26, 2010 | Apple iPod touch Second Gen (8 GB,...
HOW CAN I UNLOCK MY IPOD TOUCH?
I would recommend using a program called disk aid to extract all your media to your computer then restore your iPod and put your media back on your iPod here is the URL to disk aid: http://www.digidna.net/diskaid/download.php
To get disc aide to display your files on your iPod in the bottom left hand corner is a drop down arrow click on it and select one of the folders then in the main menu window you should see a bunch of folders hope this helps
Aug 02, 2009 | Apple iPod touch Second Gen (8 GB,...
Forgot ipod passcode
simply plug your ipod into itunes to unlock the code
Jul 23, 2009 | Apple iPod touch Second Gen (8 GB,...
8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
if you need any further help let me know.
Good Luck
Jun 01, 2009 | Apple iPod touch
Apple iPod touch Logo
371 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
