I have a LG intellowasher WD-8013C and the door will not open. The washer is empty. Can you give me any solution. Kind Regards Vicky
  • gjk24 Jul 13, 2008
    I can't open the door on my LG WD-8013C washing machine, it just finished a cycle and still has clothes in it.
  • Cara
    Cara Mar 28, 2014
    I can't open the door on my 7kg intellowasher DD, it too has wsahing in it
The washer is empty and cant open the door
Posted on Feb 03, 2010
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
Lg intellowasher 7kg wd 8013c
the push to on switch may be not in operation pl.. check
Oct 01, 2017 | Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
I bought my LG Intellowasher WD-8016C second hand and have no manual. Does it need to be washed occasionally with washing sda. There is a bit of mould around the seal. How do I clean this.
Manual suggests Exterior with household detergent. Do not use methylated spirits, diluents or similar products.
For internal, dry around the washer door and run washer through a complete cycle using just hot water... and repeat if needed.
Not sure about mould.... not in manual.
Nov 02, 2009 | LG WD-16115FD Front Load Washer
Need diagram of installation of door handle WD-8013C washing machine, have new part but cant fit please help
www.apwagner.com. You will need the model number. The diagram will give you a general idea of the assembly, but no directions. Good luck.
Sep 28, 2009 | LG Washing Machines
Lg wd-8013c washer door latch broken. Is there an emergency release?
Run a shoelace between the door and the face of the washing machine, starting at the top, over the latch on the middle of the right hand side and down to the bottom.
Pull both ends of the shoelace towards the hinge on the left.
This pulls open the latch with NO DAMAGE and allows access to the screws that remove the latch mechanism. Easily ordered and installed with two screws and a plug to reattach.
LG give no support or reference to this easy procedure in their manual. SHAME!
Sep 14, 2009 | LG Washing Machines
Cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Apr 25, 2009 | LG Washing Machines
Lg washer model no wd 8013c door wont open tried everything and the child lock is disengaged
How to get the door open:
Thread a shoelace between the door and the front of the machine from the top, over the latch on the middle right and to the bottom. Pull both ends of the shoelace towards the hinge on the left and this will manually pull open the latch with NO DAMAGE. Once open you can access the screws to remove the mechanism and simply buy a replacement.
LG, bloody hopeless support and no simple way to rectify this problem in the manual when it's so easy once you know.
Jun 19, 2008 | LG Washing Machines
Washing Machines Logo
640 people viewed this question
Top Washing Machines Experts
