I makes a very loud noise - Heating & Cooling
  • 1 more comment
  • Anonymous Jun 07, 2008
    yes, i just turned mine on for the first time and it makes a horrible scraping noise. I can't see what the blades could be hitting but it sounds like the styrofoam inside.
  • Anonymous Jun 08, 2008
    Horrible scraping noise on startup and intermittently during operation.
    I took off the front panel and started up the unit. It's the fan rubbing up against the Styrofoam that isolates the fan.
    All of the less expensive brands have this design flaw as far as I can tell. I'm tempted to partially disassemble the unit and get rid of the Styrofoam piece.
    Any suggestions?
  • roger383 Jun 11, 2008
    My Electrolux A/C's fan scrapes against the fins on the back of the unit. In fact, it is so far out of alignment that the motor jams and won't turn. (However, the cylindrical part of the fan on the other end of the motor shaft is not touching the foam and appears to be aligned correctly.) This started happening after the unit was dropped.
    I assumed initially that the fan had slid out too far along the motor shaft and was now interfering with the fins. However, there is an E-clamp holding the fan at a certain place on the motor shaft, so I assume it is supposed to be in that position. The motor still works (so I don't think the shaft itself has come out of alignment) and its housing is at a fixed distance from the fins - am I missing something? Thanks in advance.
  • 26 Answers
Had same problem with Ge AC. Unplug take out of window and remove all cover screws. Pull up on cover and pull cover off ac, Remove front cover as well there are a couple screws in the front. When looking at front of ac, hit the Styrofoam housing towards your left (towards control panel). Spin fan blade to make sure that it is clear. Plug in to double check. I put a couple quarters between the styrofoam and the metal housing, so it would not slide back. Also tape the styrofoam between the seams this helps with better cooling. Use some good tape nothing cheap. I used black duck tape. It took about 20 mins. The hardest part is re installing the AC.
Posted on Jun 02, 2012
  • shaundavis80
    shaundavis80 Jun 02, 2012
I HATE THIS STUPID SH*t cheapass a/c unit.
ALWAYS LOUD ON ALL ITS MODELS!
Quietmaster? RIGHT! This should be scrapped off the market immediately
Posted on Jun 09, 2008
Im having the same problem on the panasonic cw-xc103hu, it seems like the fan is rubbing on the styrofoam during startup and intermittently - I've lost an entire nights sleep because it was so loud. Any suggestions?
Just bought a Gold Star WG5005R
Makes a horrible scraping noise on startup and intermittently during operation.
I took off the front panel, started the unit and observed the fan rubbing against the Styrofoam enclosure that it sits in.
I'm inclined to just partially disassemble the unit and remove all the Styrofoam. This design flaw seems common in the inexpensive 5000 btu units.
Any ideas on how to solve this problem without ripping out the styrofoam??
Posted on Jun 08, 2008
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
New AC makes loud noise
I would call contractor back
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
Roof air unit too loud inside; quiet outside.
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Compressor of the Ruud A/C outside unit is making unusal loud continuous noise. I open the case, its not the fan or fan motor, loud noise is coming from the compressor, and it is also heating up a lot....
OK, you will need to replace this compressor. the internal seals have ruptured, causing the loud noises. the heat is from the metal to metal friction. the compressor can be rebuilt but, it will be more costly than just replacing it with a new compressor.
May 27, 2009 | Ruud Handle Air Conditioner
My Air Conditioner makes a loud buzzing noise now. It didn't do that before, now it makes so much noise I can't hear anything over it
Buzzing noise - contactor. maybe a bug got in the contacts or maybe the coil is bad but in any case if you replace the contactor the buzz will go away.
May 23, 2009 | Goldstar Heating & Cooling
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Loud noise
It is probably a rotary compressor unit.
They tend to make a start up noise.
Some technicians advocate adding a booster starting device to help the compressor start more quickly, thereby reducing startup noise.
Mar 12, 2009 | Heating & Cooling
Heating & Cooling Logo
610 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
