Question about Ovens
I have an older Beaumark oven and stove. we took the oven door off and cannot get it back on. What is the trick to it? It is Model #18250-2 serial#JC188741
  • 4,066 Answers
Open or pull the hinges out to the first stop position. (broil) You should now be able to insert the hinges into the bottom of the door at the same time.
Posted on Oct 13, 2010
Took maytag oven door off to clean cannot get it back on hinges will.not stay open and keep.snapping back fingers r sore took a pipe to pull them back but they wont stay How do I keep them from snapping...
It is a two person job unless you want to pull the whole stove out and take the cover off and then remove the springs. Put the door back on and put the springs back and the put the cover back on.
Oct 10, 2014 | Ovens
My Kenmore range model # 790.9601 is acting strange. My stove would loose power when I opened my oven door, when I would shut it the range would buzz and then the power would come back on. It did this...
This seems like a power issue, as you disconnected it and reconnected it with limited success. I would believe that the power is ok into the machine, but from there there is some wiring inside that needs attention, perhaps the machine is an older model and they are corroded to a point that there is a short or similar problem inside.
Use care and check inside to see if you see a short or broken wire. Let me know if there is any other assistance I can give,
Joe
Sep 13, 2011 | Ovens
BEAUMARK OVEN OLDER MODEL ELEMENTS WONT HEAT UP. FUSES ARE NEW AND GOOD.
Hey did you ever get your oven elements fixed? If so where did you find them - I have same problem (just with bake element)
Sep 01, 2010 | Ovens
Kenmore oven door will not unlock, it is an older model and i have lost the manual. i tried to activate the self clean but i couldn't remember how all that ended up happening is that the door has locked...
Look around the console area for a button that says push to unlock. If it is there push the button in while unlocking the door. Some models may require that you also place the stove into self clean then canceling it out thus enabling you to unlock the door. Without a model number off stove tho it is all just guess worjk as all stoves are not the same.
Feb 28, 2010 | Kenmore Ovens
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
How do you install oven door on Beaumark Model 13340-1
Figured it our by myself - the 2 hinges (long and short have to be "hooked" together and then inserted into the oven hinge opening.
After I solved it found the solution is also posted on appliance repairs- how to remove and install oven door. It also posts pictures.
http://www.applianceaid.com/oven-hinges.html
Jan 23, 2009 | Ovens
Oven Door
I have spilt water inside the glass of my Fridgaire stove and wondering how to take the glass off the front so I can clean inside it.
Jun 02, 2008 | Ovens
Beaumark stove
I also don't have a manual, but work on computers so tried some buttons and they did the trick.
On the left hand side is the button that has Mode, and then a series of buttons.
On the right hand side there is a series of buttons, and one looks like heat coming from the bottom. Turn this button to that setting.
On the left side, press the mode button, and then press the button that looks like a thermometer. This is the mode for setting the temperature of the over.
Beside the display windows, there is knob that looks like a dial on an analog clock. Turn this dial until the temperature you want appears.
Oct 23, 2007 | Ovens
Whirlpool double oven rb130pxv
As long as you line up the hinges with the receptacle in the door, it should slide right down. Try a shot of WD-40 on both.
Sep 08, 2007 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
123 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
