Question about Whirlpool SB160PEE Gas Single Oven
What does the code 'F2' mean on a Whirlpool oven?
  • 254 Answers
Oven temp sensor shorted
Posted on Oct 13, 2010
Testimonial: "thank you!"
3 Suggested Answers
  • 84 Answers
SOURCE: error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Posted on Dec 13, 2009
applianceboy
  • 77 Answers
SOURCE: ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
check the operation of the micro switches on the lock motor. that they are open when they should be and closed when they should be. often they need to be cleaned or replaced. if this doesnt help re post there is some board work to do, i would suggest a tech do this part though. always unplug range when you work on them! good luck.
Posted on Sep 28, 2007
Whirlpool electric double wall oven error code E2F6
Good Morning!
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Mar 22, 2017 | Whirlpool Ovens
How to remove side panels on a whirlpool Gold double oven, in order to remove control panel. I would like to reconnect the control panel, it may reset the panel to work again
Hello Ms Jackson,
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty. http://blog.fixyourboard.com/2015/08/20/gbd-rbd-whirlpool-oven-problems-causes-and-solutions/
I've also attached a link on how to remove your Whirlpool oven control board How to Remove Whirlpool Oven Control Board
Feb 10, 2017 | Whirlpool Ovens
What is the eo f2 error code mean on a whirlpool oven
E0 F2 is a stuck key on the keypad. If your keypad is not available from the factory you may find a replacement unit here: http://www.fixyourboard.com/ledgestone.html
Aug 17, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Rbd275pdb12 - trouble codes f2 e6 - what do these codes mean?
E6 F2 on a whirlpool double oven translates to "Cancel Key drive open". We see this frequently and is always a problem with the control board. At www.fixyourboard.com it can be repaired quickly and reliably at a fracton the cost of a new board.
Jun 03, 2010 | Whirlpool Ovens
I have a Whirlpool Oven RBS305PDS16 is having an error code E1 F2 and then it shuts off. What could be wrong?
E1 F2 means bad connection between touch pad and control board. if connections are ok it may require parts. may get very expensive.
Aug 20, 2009 | Whirlpool RBS305PD Electric Single Oven
Whirlpool SB160PEE Gas Single Oven Logo
1,416 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
