Question about Sony FD Trinitron WEGA KV-34XBR800 34" TV
My will not work with the remote any longer. I replaced that. When I manually turn power on, it takes 3 or 4 times before coming on. Then, it will turn off after about 30 seconds. ANy ideas?
    Top Expert:
  • Sony Master
  • 74,106 Answers
There is an infrared sensor inside the tv to receive infrared signals transmitted by the infrared signal generating light emittin diode fixed on your remote control. Either the sensor inside the tv or light emitting diode in the remote controller faulty, remote function will not work. For manual operation troubles, check the wall power socket of plug of the tv is faulty, loose contact etc.
Posted on Oct 14, 2010
My Hunter remote controlled fan worked great for the first few years, but now the the light comes on and the fan turns off at the same time without me touching the remote or the switch on the wall. Wakes...
Sorry to read about your problem, I hope this helps you out.
you may have a defective remote reciver or even a bad remote.
Take the battery's out of the remote for a couple of days, if the fan turns on, the remote is good.
you can have the remote receiver replaced, they run around $60.00
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Hunter 52" Ceiling Fan With Light And...
40 inch samsung, little over two years old. trun on the tv with remote or manually the tv just ckicks about 3 seconds between clicks and takes a few minutes to come on .. seems to slowly ...
hi there.your set needs four new capacitors fitting on the power supply.they are grouped together,if you take the back off,you will see they have domed out on the top,and may be leaking brown fluid.if you are reasonably handy with a soldering iron,replacement is dead easy.caps are only a few pence each,take note of the polarity when changing.this is a VERY common problem.
regards,steve.
Sep 13, 2010 | Samsung Televison & Video
Problems turning on
The tv power supply board have problems,it the board with the a/c power cord plug into it.That the tv power supply board it dying.Replaced the power supply board will solved this.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 21, 2010 | Toshiba REGZA 47HL167 TV
Have a 42'' lcd legend and have similar problems. It started taking about 5 minutes to turn on, then longer, then longer, until finally it didn't come on at all. The power light goes from red to blue, but...
The problem is inside the vga hdmi board ,i have repaired 2 of these units the 37 inch version and found a bad 100 microf 10 v capacitor . a little bit of soldering/de soldering skill is needed . cost of cap 0 dollars got it from old radio.but it takes along time to repair-you have to remove the back cover and note lot of screws .ernie
Jan 12, 2010 | Televison & Video
Masterplug 4 in 1 remote control
There is no bush listing in the manual
You can perform a manual search.
Press and hold TV,SAT,DVD or VCR until the centre light blinks red.
While it is blinking press 0000
The flashing will speed up.
Press the power button repeatedly - it will cycle through all codes.
When your device turns off (powers off) press the okay button.
It should now power on and off correctly.
Check the other buttons to see if everything works.
If it does not start the process again - it will hit another code which will also power down the device - takes a long time but should work - manual states it may take 20 mins - practise says longer
Jan 19, 2009 | Philips Magnavox Learning Universal Remote
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
CONTROL CODES FOR HITACHI DV-RMPF2
I found the user manual online - directions are:
Turn TV off
Hold RED TV Power button down
and at same time per manufacture of TV...
Hitachi - 1
Sony - 2
RCA - 3
Sanyo - 4
Zenith - 5
Panasonic1 - 6
Panasonic2 - 7
Sharp1 - 8
Sharp2 - 9
Toshiba - 0
JVC - Clear
Mitubishi - +10
Magnavox - SUBTITLE
Funai - AUDIO
Goldstare - DISPLAY
voyageurs60
Jul 10, 2008 | Televison & Video
Problems programming TVTECH universal remote controller
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Jan 06, 2008 | RCA RCR412C Remote Control
TV will not turn on.
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
