Question about Singer Tiny Tailor TT700
Hi, I bought a Singer Tinytailor (TT600A) Mending machine recently. The lower thread is not coming up when the needle goes up and down. I referred to the manual. But it is not of much help. Please help me out in resolving this.
2 Suggested Answers
2coolrick
  • 560 Answers
SOURCE: a friend gave me a
make sure your bobbin is threaded correctly from the spool and through the eyelet. with 4 or 5 inches of thread coming out of the bobbin and install the bobbin. Then, hold onto the end of the thread that is threaded through the needle while you manually rotate the spinner allowing the needle to drop all the way down and backup again . If everything is right, your needle thread will come up with the bobbin thread as you slowly pull on the needle thread and rotating the spinner . Make sure you rotate the spinner wheel the same direction it normally rotates while running .
Posted on Oct 23, 2010
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
I just purchased a singer cg-550/500 and after threading the machine and inserting the filled bobbin, I was unable to bring up the bobbin thread with the needle. I followed the instructions carefully but...
if im not mistaken, the bobbin when you place it in the bottom, you have to thread it is as well to the part where the needle comes down and collects and goes back up. please re-look at instructions for placement of bobbin
Mar 05, 2011 | Singer Sewing Machines
I have recently bought Singer Quantum 9940 and I am not happy with the stitch. For zigzag stitch, I can see too much of the upper thread on the bottom side. This happens unequally: more on the right hand...
1. Make sure your needle is correct for the fabric. Go buy some good needles in several sizes. You'll need a 90 for jeans, rounded points for fine fabrics... get a few sizes. Your manual should provided you with clues to the right needle for the fabrics. (BTW... there really is no such thing as a Universal Needle... toss it.)
2. Re-read your manual and carefully follow the instructions on threading the bobbin and the upper thread...
3. Check your tension on the upper thread... it is too loose for the application. The tension on the bottom thread is handled by a spring on your bobbin case or race. If you do not have that threaded properly you'll have problems. Same with the direction the bobbin turns... have in it backwards... problems.
Barring all these things... It might be time for a qualified Singer repair person to look at it. Sadly Singer has seriously lowered it's standards in the last 20 years.
Feb 05, 2011 | Singer Quantum 9940 Computerized Sewing...
A friend gave me a Singer Tiny tailor 700 Mending machine recently. The lower thread is not coming up when the needle goes up and down. I referred to the manual. But it is not of much help. Please help me...
Oct 23, 2010 | Singer Tiny Tailor TT700
Singer TT600A needle is moving, but stiches are unformed. I've tried everything. I've already changed the tension and did everything in the manual repeatedly.
Make sure the needle is installed with the flat side of the needle shaft to the back of the machine.
A sewing machine should always be threaded with the presser foot up. This opens the tension control so the thread can "seat" into the control.
When a sewing machine is threaded with the presser foot down, the tension control does not open to properly accept the thread.
If the machine is already threaded, lift the presser foot and pull about 6" of thread through the needle.
Last resort: the machine needs to be taken in for service. Sometimes the stitch is not forming because the timing needs to be adjusted.
Apr 01, 2010 | Sewing Machines
Cannot get the bobbin thread to come up with the top thread
1. Make sure the needle is up in the machine all the way.
2. Make sure the flat side of the needle is facing the rear of the machine
3. Only turn the handwheel on the side of the machine towards you, never away from you.
4.Double check your threading of the top of the machine.
5. Also make sure your using the proper needle, your machine takes the most common needle on the market but some look like it and are shorter or longer and wont work properly. Also make sure your not buying needles for a singer serger.
Oct 07, 2009 | Euro-Pro 473
HOW TO THREAD THE TINY TAILOR
check this site out for a mnual Singer_ TINY-TAILOR-TT600-TT600A Manual - Only $5.00 for the ...A Handbook for your Singer_ TINY-TAILOR-TT600-TT600A Sewing Machine ... Download the TINY-TAILOR-TT600-TT600A Singer_ sewing machine manual: ...
http://gotoes.org/sales/Singer_SewingMachineManuals/ViewInfo.pl?Singer_=1&Sewing_Machine_Model=TINY-TAILOR-TT600-TT600A
Aug 28, 2009 | Singer Tiny Tailor TT700
Singer 301A needle breaks
do you have a book, refer to threading. This machine threads differently than most, threads like a 221 featherweight. Needle goes in backwards, and threads backwards. in wrong and you can have problems, also threading can cause your problem if you have missed tension or a thread guide. great little machine
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Nov 24, 2008 | Singer 3116 Simple
Inserting needle on old singer machine
Hi Terry--
If your machine is 40-50 years old, it might be a Singer Featherweight portable. (If it is, you have one of the very best machines ever made!) On the Featherweights, the flat of the needle faces left (and the needle is threaded from right to left). The bobbin goes in a bobbin case; you'll see a small notch when you look down on the bobbin in the case. That's where the thread goes. I'll email you direct with more information.
Lookingpast
Dec 26, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
105 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
