Question about Sony PlayStation® 3 (60 GB) Console
When i hook ps3 to tv the power will come thru but no picture
    President:
  • 2,653 Answers
First thing to try is a soft video reset.
While the PS3 is off (solid red light), hold down the POWER BUTTON until you hear the SECOND BEEP, quickly release.
Let me know what happens.
Posted on Oct 13, 2010
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
I just bought a used ps3 i hook it up to my emerson hd tv and it shows format not supported , i then hooked it up to my poleroid hd tv and it works fine this all thru the hdmi cable
What are the specs on your emerson, does it support 1080p? Make sure you have the right settings on your ps3. If your emerson supports 720p and 1080i then it will not give you a 1080p picture and you might run into issues.
Mar 06, 2011 | Televison & Video
Trying to hook-up a PS3 to my Toshiba 32AV500U thru HDMI but I get no picture. I forget how to get to the setup.
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Nov 25, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
No picture thru hdmi but picture thru RCA plugs
I had this exact same problem, or rather my friend did after I borrowed his PS3. You see when I borrowed it, the console configured the HD output to work with my TV, If this happened to you, there is a fix, With the HD cable connected, turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. Once you can then get something on the screen, you can configure the video settings to match the TV you are hooking up to.
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
When i turn on ps3 all i get is a blank tv screen? hooked up thru hdmi. triied another hdmi cable i know works still a blank tv screen
when you turn your ps3 on ..try holding the power button down for about 10 seconds..that shud cure your delema..if the ps3 is working properly
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
60GB PS3 had been hit by a power surge. HDMI not working.
hook up the ps3 thru the regular yellow composite and HDMI. Go into the settings and change the output to HDMI and then see if you can get video thru the HDMI, if you don't then the mainboard is bad and you would have to send it to Sony unless you can get your hands on another broken sony ps3 with a good main board.
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Ps3 reset
turn the PS3 off. hold the power button for at least 5 seconds or until you hear another beep.
This should reset all your ps3's settings.  If you have an HDMI connection, wait for a couple of seconds so that the PS3 recognizes and negotiates the right video output for your TV.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Hooking up playstation 3 to tv
you need a ps3 scart lead. i think the one of the ps2 is the same but check. it should just hook up like a ps2. if you are having any problems with the picture hold down the power button when you start up the ps3 for 10 seconds this runs the optimal screen settings for the cable you are using. but if it is the first time you are using the ps3 it will auto start in set up mode. hope this helps
Jan 09, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
