Question about HP Photosmart C6180 All-In-One InkJet Printer
The HP Photosmart c6180 appears to be in a loop. It tries to boot up and then displays a message, "To avoid damage, use the On button to shut down the printer. Do not use a power switch or wall outlet to shut down"
  • HP Master
  • 7,733 Answers
Go to ->link..
Posted on Oct 13, 2010
3 Suggested Answers
  • 100 Answers
SOURCE: HP Photosmart C6180 turns off and on repeatedly
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the Printer was having.74b7f9c.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these
Posted on Sep 28, 2010
MSG-CPC
  • 1325 Answers
SOURCE: what can I do to fix this problem? HP Photosmart
hi
to solve this issue, write down everything you see oin your computer and/or the printer control panel. send it to me and i will investigate further to help solve the issue.
go to this link and review the instructions (1st link)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01369982&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=1153494
if this deosnt solve issue go to the second link below, and review related soltions.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=27286&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=1153494
please rate my solution
Posted on Nov 19, 2010
How can i fix my C6180 HP photosmart computer with msg of improper shutdown from wall switch
Try what they call a hard boot. In other words completely power down ththe printer by either removing the power cord or shutting down via the power button. If this does not work try to enter the menu and clear the arror code manually. Hope this helps.
Sep 08, 2012 | HP Photosmart C6180 All-In-One InkJet...
What can I do to fix this problem? HP Photosmart
hi
Nov 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer on button keeps flashing. How do I shut down to restart? Printer screen keeps flashing as well. Says to shut off to avoid damage.
Just unplug it from the wall. Then open the flap and look for what might have caused the warning - usually it's paper block - and remove it.
Jul 30, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
The ink system not working
here. try to reset your printer. this will clear annoying error displayed on your printer
1. Remove all cables
2. Unplug the printer power.
3. Press and Hold down # and 6 on the keyboard.
4. Plug the power cord back in.
5. Then release the buttons....after successful boot operation, try to print.
If that did not work.. you can also try this.
1. Press/Hold down the HELP and OK button..then unplug printer..release the button
2 Press/Hold down the HELP and OK button again..then plug the printer back in. Just Press and hold down the button while you wait for the printer to turn on (it could take a minute)
3 Now release the buttons and power it back on.
4 Error message will be displayed “improper shut down”
5 Press OK to reset the printer
6. Press both HELP and OK button again to start the resetting procedure of the printer.
Now try printing again...
If you find this very helpful..please rate this solution and vote on this on the YES below....thanks..
Jun 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 turns off and on repeatedly booting (looping) error message says to avoid damage use the on/off button when shutting down. do not use power strip or wall switch
Mar 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 boot - init loop / power on-off loop
The Formatter board (main logic board) is faulty. You need to take the printer in for repairs to HP, in my experience though it usually works out better to replace the printer.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer cycles on and off continuously
make sure that the switch is properly pressed on and it pops out again.
Jul 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Same problem, hp c6150 turns on and shuts down in infinite loop.
In visiting with HP Support Personnel, this issue is most likely caused by a faulty power source. I have the same issue with our C6150 and they recommended that I look at replacing power cable. I am currently trying to find a new power cable.
Jun 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
229 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
