Question about Mtd 22" Yard Machine Push Mower
What is the proper oil heavy for the 22"rotary mower model series 260
  • Mtd Master
  • 7,482 Answers
Use a standard non-detergent oil 30W
Posted on Oct 14, 2010
  • 2strokeguy
    2strokeguy Oct 21, 2010
    Please, please don't use a non-detergent oil. No engine manufacturer has recommended non-detergent oil in nearly 20 years. Use a SAE HD30weight oil.
30 weight
725 Series Electric Start Rotary Lawn Mower 22" Multi-Cut Model No. The 917.370931 Does the battery need to be charged before it will start with the pull rope?
no
it is the same as a car with a flat battery
turn it on and then push it and it starts
the same as the mower --turn it on and pull the cord
Jun 08, 2017 | Electric Garden
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
Rotary lawn mower
Are there possibly spacers that are missing from the Blade?
Sep 07, 2013 | Garden
What kind of oil goes in my craftsman 625 model 944.367600
Tecumseh engines usually recommend SAE 30 oil. Briggs engines allow 5W 30 or 10W 30.
Aug 01, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman rotary lawn mower 675 series Briggs and Stratton engine 22" multi-cut Model#917.370430 My question is concerning about engine failure. My mower has stopped running and there's gas in it and...
You cant remove one without the other, buy yourself a vacum pump ( there are plenty of cheap hand operated syringe types available ) and suck it out through the dip stick hole.
Jun 07, 2013 | Garden
Engine growing black smoke
Usually this is a sign of oil being in the ignition chamber. Check the oil level, if too high drain and refill to proper level. Also if you have hills or slopes in your yard make sure that you are mowing up and down not across. If you must mow across the slope make sure to do it with the oil to the downward side. Caution if you do this too often the engine will be deprived of oil all together and seize up.
Apr 18, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
How to change oil in poulan pro 650 series model hp-22 mower
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Apr 14, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Sep 27, 2009 | Poulan Pro " Pro" Self Propelled Mower
Mtd 22" Yard Machine Push Mower Logo
130 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
