Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Aqualink rs flow light on, has new flow sensor
  • 990 Answers
Make sure the sensor is installed in the correct direction. Their should be an arrow stamped into it somewhere to tell you the direction of water flow. Then check to be sure the filter is clean. It will slow water enough to not trip sensor.
Posted on Oct 13, 2010
  • lancebalt Oct 15, 2010
    know to install sensor in correct direction,hayward cartridge filter cleaned a month ago
  • Kieran Ruppert Oct 15, 2010
    Make sure that your impeller is clear. You can reach in the front of the pump behind the basket with a pair of needle nose pliers and feel for a clog. If you can't feel this out or are unsure of what your looking for you may need to open the pump up and look at the impeller and use a wire coat hanger to clear the veins. This should get the water moving again. Let me know how you do.
The system keeps showing "no flow" and the hand held asks to check aquapure.
inside aqua pure there is a card hooked to the salt sensor cable there is a button to hold down until a green light shows then see if you get flow if not need new sensor
Jun 20, 2013 | Jandy AQUALINK RS TELELINK KIT
Aqualink RS4 Water temperature reads 120 - obviously wrong.
No but this sensor is easy to replace. Just pull the sensor from the pipe by loosening the staniless steel clamp that holds it in the pipe. Then follow the wire back into the Aqualink box and unplug. Get a new one at your local store and replace. It's a common problem and you should be able to do it with ease.
May 21, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
132 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
