My baird tv remote control (hyf-51d) has stopped working properly. The channels dont change properly and the blue light on the front of the telly flashes as soon as you turn the remote towards it without pressing any buttons.
freetek
  • 5568 Answers
SOURCE: im havin problems settin my
You may have two settings to change; make sure that your laptop has its external VGA turned on. You may have to access the CMOS setup or choose an external monitor from the Control Panel - Display settings.
On your TV, you will have to change the input selection which is probably set for 'Cable' now. You didn't mention the model number of your set so can't check which verbiage is available through your menu. Once you have found the input selection section of the TV menu, if VGA is not specifically mentioned, just have material set up on your laptop (movie or similar) and step through the possibilities - slowly - so your set has a chance to see if signal is available from the selected input.
If it is still telling you 'no signal,' your laptop may still not be outputting anything to the TV.
Posted on Aug 27, 2011
wyoed1
  • 211 Answers
SOURCE: Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 27 Answers
SOURCE: Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
please rate my answer it is much apreceated
Posted on Feb 13, 2009
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
Could anyone help me i have a baird jo32 tv does any one know wat the correct codes is so that i can use my sky tv remote to controle my tv?
Hello
Codes for
Baird TV with Sky Plus are:
137 221 371 218 220 101 236 100 033 245
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Jul 10, 2011 | Televison & Video
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Tip
How to program an rca universal remote without codes
If you have a universal remote but dont have the codes or the codes dont work then what you can try is to scan all the frequencys using the remote to manually scan to work for your telly or other equipment your trying to control.
Follow these simple instructions
1. Turn on the device you want the control to control ie the tv or dvd or stereo etc
2. You need to now press and hold the button for the device you want to control and also the power button untill the light on the remote stays on( for this case we are going to program it to control a tv) so press and hold the tv button and power button hold them down untill the light stays on
3. press the play button once every 5 seconds( a bank of 10 codes is being sent every time you press the play button)
4. when it turns the tv off wait press the rewind/reverse button and check it turns the telly back on if it does then you need to hold the stop button untill the light goes off.
Once you have done this check the remote is working properly ie changing channels ets if it dont work properly then follow the instructions again and try again you may need to do this a few times till it gets the right signal
on Jan 18, 2010 | Televison & Video
Video input
Hi the only slight chancer you have of doing this without the remote and this will only work with some tellys is to have the telly switched on then the device you have connected to the video input have this switched off at the wall then with the telly on switch the device on your trying to get the telly to pick up now some tellys will pick up the signal and go to that input channel, if how ever this dont work your going to need to go out and buy an all in 1 remote, these remotes cost next to nothing to buy you can get them off the well known auction site or from your nearest cheap shop such as discount stores that sell goods for next to nothing these remotes will work on all tellys and would solve your problem if the way i told you dont work.
Im sorry their is no easy way to get it to change but without the remote your pretty much stuck unless on the telly you have a button that looks like a square with an arrow running from left to right if you have this button then pressing this wil change the input source for you, if you dont have this then the only option would be an all 4 1 remote.
let me know how you get on or if you need further assistance ok
May 31, 2010 | RCA TruFlat 27F520T 27" TV
Have ps3 that was working fine, unhooked it from one tv to another and proceeded with holding the power button 5 seconds til it beeped twice and still have blank screen
hi, if the ps3 was working fine on the other tv and you have not dropped it or anything like that then this would point towards their being a fault with the lead of the connection in the back of the telly.
what you should do is unplug it all again and refit all the leads in the back of the ps3 making sure they are pushed in far enough then plug the lead into the back of the telly making sure you push it in far enough, then switch the telly on and then switch the ps3 on if the telly dont change to the correct channel as soon as the ps3 comes on then you need to get the telly control and put the tv on the correct channel.
now depending on how many inputs the telly has would depend on how many times you press the button on the control, the button you need to press is going to be on of the following its either av, input,source,ext,aux, or a picture of a rectangle with an arrow running from left to right, now once you have found this button make sure your ps3 is on with a game in then press the button on the tv remote then wait couple of seconds it may say something like av1 on the telly if this dont show the ps3 then press it again it should then go to av2 and keep going until you see the game on the ps3 you need to keep going until your telly is on the right input channel.
once you have done this your ps3 should be working again.
May 25, 2010 | Sony Playstation 3 (PS3) Console
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
My remote does not work with my bush a632 tv. i tried changing the batteries adn using a different remote but it still doesnt work. The tv light flashes when pressing buttons on the remote but it doesnt...
Hi there we had same problem so phoned 08456040105 and they told me to press menu button on tv for 10 secs and take batteries out of remote and press power button on remote for 10 secs while batteries are out. it worked for us doing both at same time....good luck
Asker's Testimonial " Oh my goodness thank you so much for this advice. I was a bit sceptical but it worked wonderfully!! " - aurora393
Feb 06, 2010 | Televison & Video
Need a code for my sky control to run the tv it is a baird model no is JO47BAIRD
follow the steps below using your sky remote.
TV
RED + SELECT
TV
0117 (manufacturers code)
press power, if this turns tv off press SELECT to save. if not press TV then POWER again. when the remote turns your telly off remember to press your SELECT button to save it to your sky remote.
Enjoy
Cheers
Little Dish Fitter
Sep 02, 2009 | Televison & Video
None of my remote controls will control the volume on my samsung
buy yourself a cheap sky remote or get one off a friend or family member.
on the sky remote:
TV,
RED + SELECT (blinks twice)
TV,
0060
TV,
SELECT.
there you go you can now use this as a telly remote and change your channel over, volume, power, if you press the help button this will also change your source/av's
Cheers
Little Dish Fitter
Sep 02, 2009 | Samsung Remote Control
I cannot get my universal remote to work!!! we have tried everything and it will change the channel once and then it doesnt work. i have tried all the combo codes and im getting really mad!!!!!!!!!!!
Hi have you tried manually searching for the frequency like it says in manual untill it turns the telly off then store this frequency in the control if this still dont solve your problem then the remote is faulty because if your telly is listed in the code sheet then it will work on the telly if not then the control is faulty so take it back and get a replacement ok.
What make and model is your remote?
What make and model is telly?
let me know then ill look for you ok
Apr 22, 2008 | Televison & Video
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Electro Med Services...
