Question about Sharp 25R-S100 25" TV
Repeated burn up horizontal transistor
How i get out of old technolgy????? dear BUBRUCE
  • solver gariz Jun 05, 2008
    thankyou very much! i will know what that mean!!!dear BUBRUCE!
    Problem Solver:
  • 14 Answers
Sorry if that sounded kind of kurt. All that i ment is that the price of repeadly fixing an older tube tv may start to outweigh the price of a new flat panel tv. Also samsung (if you like that brand) is still making high definition slim fit tube tv's. Which is an older technology driven tv with new bells and wistles. Also sony's XBR line is an absolutely fantastic tv. When tube tv's were being mas produced sony came up with the XBR line and have been using it ever since. If you can find an XBR series tube tv for a reasonable price you can bet on the fact that it will be a phoneminal tv without spending the mass amounts of money on a flat panel. But as for the repeated burn up of your transistor i cant be of much help. And if thats all you care about doing is fixing the tv you already have well then i just wasted a few min. of your life. I wish i could be of more help on this.
Posted on Jun 03, 2008
How to repair tcl 21189 u h-out always shorted
If horizontal output transistor shorts repeatedly, the reasons are so many.
Freewheel capacitor [****pF 2500V]
Shorted winding in the deflection yoke.
Horizontal oscillation frequency is more than normal. [Main IC fault]
Over voltage B+. [Comes out from SMPS]
Horizontal drive transistor and/driver transformer fault.
Check all these. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 11, 2014 | Televison & Video
Samsung hcr5245wx xaa
It sounds that the horizontal output section circuit has the fault. The horizontal output transistor might have burned out. Check it.
May 23, 2013 | Televison & Video
The TV will not turn on. It blinks in standby for 6 times and shuts down.. Unit is about 10 yers old.
6 blinks = No Horizontal (H STOP), no raster, goes to the blinking self diagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206 (or similar component references for your model) and replace flyback transformer if required.
Generally, whenever horizontal OCP (over current protection) occurs, the primary cause is usually the flyback transformer (these short circuit/burn out), the horizontal output transistor(s) and the tuning capacitors in the transistor(s) collector circuit must all be replaced together. It is also a good idea to check the ABL (or beam limiter) circuit as components may have been compromised in it due to the failing flyback.
You could take it to a service centre and obtain a quote for estimated repair costs, then you can decide afterwards if it is worth repairing or not. It may not be economical and/or expensive.
Mar 03, 2011 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
My 36xbr800 blinks six times then pauses then blinks six times, this is repeated......
Check the voltage input to horizontal output transformer [LOT]. Check the voltage at the collector point of the line drive transistor. If the line drive transformer primary gets open this type of fault mau occur. Also check the frequency ant the collector point of line drive transistor and the base point of line output transistor. It should be aroung 15625 Hz.
Check and replace the horizontal output transistor if needy. Replacing it is better. The horizontal output is not working or a short in secondary power supply of SMPS or lot secondary, is your problem
Oct 14, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Lg flat 21 inch tv -horizontal o/p transistor burn after 1 minute & sound chik chik
You have to check the high voltage diodes near the horizontal transistor and the small transformer. Diodes might have gone leaky. Check the capacitors also.Replace the black colored diodes with new ones with identical part no.
Rarely EHT coil will have problem.
Sep 15, 2010 | Televison & Video
Tv not switching on just makin noise from power supply & hissing @ the flyback transformer with horizontal becoming extremly hot then afew min later horizontal burns out(D1398)
If the horizontal transistor getting shorted, this could happen.
Check the transistor 2 SD1398. If found faulty replace it.
But replace black colored doides in the circuit as a whole.
Leaky diodes can not be determined easily with the multi meter.
Especialy the small high voltage diode near the small transformer
connected to the 2 SD1368 transistor.
Sep 03, 2010 | Televison & Video
I have a 1993 36 inch RCA, model # P46151WK. TV was on and suddenly heard something pop and it started to smell like something burned inside. It wont turn on anymore.
You may have a fried horizontal output transistor and a defective flyback transformer. If indeed this set is 17 years old.......cheaper to replace him...sorry!
Mar 01, 2010 | RCA F32650 32" TV
Rca 2006 32v434t dead shorted out put
One special transistor is there. Before you change the transistor please sure that this is the first time problem or repeat H output TR failure. If it is first time means simply change the special type of transistor C5591. This is the high current rated tr and Panasonic is the manufacturer. Repeat H out failure means do the following simple works. If there is any capacitor between H sync output from Ic and horizontal drive transistor. Reduce the mf value and slightly increase flyback capacitor value. And then put the new horizontal output transistor.
Sep 06, 2007 | Proscan PS36800HR 36" TV
Sony blinking standby light
This is Sony's way of telling you that there is a short in you set.Probably the horizontal deflection circuit.(Horizontal output transistor shorted??). Also any other short. You need to take it to a techincian and have it checked out. It would be wise to get an estimate! Stargazer
Feb 05, 2007 | Sony KV-32CS70 32" TV
Sharp 25R-S100 25" TV Logo
96 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
